steering wheel shimmy when going over bumps - JeepForum.com
post #1 of 14 Old 07-22-2007, 11:45 PM Thread Starter
rmb2485
rmb2485's Avatar
In the last week or so I've noticed that my steering wheel (and I'm assuming font wheels) shimmies back and forth for a few seconds after I hit a bump. These are NY roads, so by bump I mean jarring bump, not smooth bump. I have a 2"BB, 1.25"BL and 1"BMML and 31" AT's. I'm going in for a front end alignment tomorrow (complements of Firestone's lifetime alignment, best $110 I've ever spent ) but should I have them check the front tires for being balanced properly too? Would an after market steering stabilizer help? I don't think theres a mechanical problem causing this because its a recent development. Probably something just thrown out of whack while wheeling? What are your guy's thoughts?
edit: Forgot to mention that this is all happening when I'm traveling somewhere in the neighborhood of 55mph.
rmb2485 is offline
post #2 of 14 Old 07-23-2007, 07:45 AM
jterp
I have the same thing on my '02 with stock suspension. It was really bad -- violently bad -- and it turned out that I had broken a sway bar end link. With that replaced it pretty much went away, but it still there very faintly. If you find anything out let us know!
jterp is offline
post #3 of 14 Old 07-23-2007, 08:08 AM
175MM BULLDOG
175MM BULLDOG's Avatar
I installed a Rancho stabilizer on my '05 Unlimited. It stopped the shimmy. I only have 26,000 miles on the rig! Whats up with that?
Gun control: "The ability to hit your target"
175MM BULLDOG is offline
post #4 of 14 Old 07-23-2007, 12:29 PM Thread Starter
rmb2485
rmb2485's Avatar
Talked to my mechanic today and he's pretty confident that its just my stock steering stabilizer on its way out. Any recommendations for an after market replacement that won't burn a huge hole in my wallet?
rmb2485 is offline
post #5 of 14 Old 07-23-2007, 12:37 PM
TheBoogieman
Still disturbed
TheBoogieman's Avatar
Steering stabilizer and Skyjacker's work fine.
TheBoogieman is offline
post #6 of 14 Old 07-24-2007, 02:28 AM
usarmyavn
I had the same problem. Replaced my steering stabilizer with a Rancho and it's fine now!
usarmyavn is offline
post #7 of 14 Old 07-24-2007, 08:10 AM
Big-E
Any heavy duty stabilizer will do, just put a Superlift Stabilizer on mine yesterday. They all run about $50. Mine was not easy, could not get the old one off. The bolt through the rod had to be grinded off & drilled out. The new shock came with a new bolt.
Big-E
Louisiana
2000 Sport
Big-E is offline
post #8 of 14 Old 07-24-2007, 09:09 AM
BoHeck
steering stabilizer fixed a problem i had like that as well
use a pitman arm puller to pull your old one off, just go slow, and i would recommend leaving the nut on the bolt on the last couple of threads, just short of removing it. when it lets go, its a LOT of released energy.
1999 TJ 4.0 manual 4.88 on 35" Pro Comp Xtreme Muds/RE 4.5" lift 3.5" springs - RE mono shocks/Dana 44 locked with ARB - Alloy USA shafts/AA SYE Tom Wood's DS/AtoZ Fab Rockers/ 60" Hanson Prerunner Style Front Bumper/Jeeperman Rear Bumper Swing Away with Side Extensions/Bestop Sailcloth tinted/Roundeyes/Infinity Sound System
BoHeck is offline
post #9 of 14 Old 07-24-2007, 09:12 AM
EDGEY
EDGEY's Avatar
One trip from LI to NYC is the equivalent to a trip out west in the mountains!
I have the same problem, steering stabilizer is next on my list to replace.
R.I.P. - 2004 Black Jeep Wrangler Unlimited LJ - 4" Rough Country N2.0, 1"BL, 1.25" JKS BL/MML, 33x12.50 BFG ATs, RC 2.2 Stabilizer, SpyderTrax 1.25s, XRC Rock Sliders, Pocket Flares
2008 Black Jeep Wrangler Unlimited Rubicon - 3"BDS, 35x12.50 Mickey Thompson Baja MTZs, Mickey Thompson Sidebiters, Bushwacker Flat Flares, Smittybilt XRC Modular Bumper
EDGEY is offline
post #10 of 14 Old 07-24-2007, 09:41 AM Thread Starter
rmb2485
rmb2485's Avatar
I contend that one mile driven on the BQE is worse for your Jeep than a week of wheeling anywhere in the country
As far as my steering shimmy goes, I had the Jeep aligned today and the toe was actually out quite a bit, so its riding a lot better now. Ordered a new stabilizer from Rusty's too so hopefully that will get me back to being shimmy free!
rmb2485 is offline
post #11 of 14 Old 07-25-2007, 07:15 AM
FuzzyDolly
For everyone I know with that problem, it's ended up being a tire balance issue. This includes myself.
Joe
2005 Solar Yellow X
2" Skyjacker BB - 31X10.5\15 Cooper STT
FuzzyDolly is offline
post #12 of 14 Old 07-31-2007, 04:12 PM Thread Starter
rmb2485
rmb2485's Avatar
Heres an update for anyone who is following along:
I replaced the steering stabilizer with one from Rusty's today and it seems to have eliminated the shimmy. The old stabilizer is obviously worn out because I can pull it in and out very easily by hand. The steering feels much less sloppy now (even though I didn't think it felt sloppy to begin with) and the wheel stays centered when going over bumps.
The install took all of a half hour. Using a pitman arm puller to get the tapered bolt out of the drag link really helped also. And, for once it was nice to have a project go exactly as planned, with no complications, and have a problem fixed for only $43 .
rmb2485 is offline
post #13 of 14 Old 07-31-2007, 04:16 PM
HitIt
I had a very similar experience and I found my front track bar to axle bolt had worked loose. Tightened it with loctite and all has been fine for a while now.
HitIt is offline
post #14 of 14 Old 07-31-2007, 06:39 PM
BlkBird
I believe there is a factory TSB on that issue also. Could check out alldata if interested.
2004 Wrangler X 4.0
2000 Cherokee Sport 4.0
1992 Dakota Sport 5.9
1971 Pontiac Firebird
BlkBird is offline
steering wheel shimmy rsant39 TJ Wrangler Technical Forum 6 08-11-2012 05:29 PM
Steering Wheel Shimmy at 45 mph after 2" Budget Boost. Suggestions? hddeuce TJ Wrangler Technical Forum 2 11-14-2009 10:39 PM
Wobble . Shimmy in Steering Wheel at 40-50MPH? fourtwenty TJ Wrangler Technical Forum 8 05-28-2007 07:14 AM
Help with Steering Wheel "Shimmy" at 35mph warner41 TJ Wrangler Technical Forum 2 06-09-2006 12:18 AM
Wheel shimmy farmboy1976 YJ Wrangler Technical Forum 3 04-19-2005 09:38 AM
