Steering Wheel Shimmy at 45 mph after 2" Budget Boost. Suggestions? - JeepForum.com
post #1 of 3 Old 11-14-2009, 09:42 PM Thread Starter
hddeuce
I have just installed a 2" BB & a 1" body lift on my 2006 TJ Rubicon. Everything is smooth except when I am between 40 - 45 mph. My steering wheel has a slight shimmy back & forth. I have not had an alignment yet. Is that my problem? Any suggestions?
Thanks.....
hddeuce is offline
post #2 of 3 Old 11-14-2009, 10:23 PM
amiller
Do the alignment then check back if issue remains
amiller is offline
post #3 of 3 Old 11-14-2009, 10:39 PM
durango-bob
2006 WK
The only adjustment that there is in the alignment is toe-in. And after you lift it, you will have too much toe-in. You can easily set it yourself with a tape measure. Just measure a common point between the front of the front tires and the rear of the front tires. Set the toe by adjusting the length of the tie rod so that you have a difference in the two measurements of 1/8".
durango-bob is offline
4 Wheel Customs Budget Boost Install yoshi280zx TJ Wrangler Technical Forum 4 10-07-2009 04:46 AM
3/4 " Budget boost wheel alighnment? Dynoram TJ Wrangler Technical Forum 5 08-21-2006 05:12 PM
4 wheel customs.com budget boost any good? jbpdog TJ Wrangler Technical Forum 5 06-12-2006 02:11 PM
Help with Steering Wheel "Shimmy" at 35mph warner41 TJ Wrangler Technical Forum 2 06-09-2006 12:18 AM
wheel backspacing and budget boost trouble seany425 TJ Wrangler Technical Forum 7 09-12-2004 02:02 PM
