steering wheel shimmy - JeepForum.com
post #1 of 7 Old 06-23-2003, 03:21 PM Thread Starter
rsant39
I recently noticed that when I am doing 55mph my steering wheel shimmies a little. At lower and higher speeds the shimmy does not exist. Anyone know what could be causing this? Thanks
2001 Patriot Blue TJ, 4.0L
rsant39 is offline
post #2 of 7 Old 06-23-2003, 04:14 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It's not likely an alignment issue. Most likely a tire is simply out of balance. Or less likely, maybe either a little mud is stuck inside a wheel throwing it out of balance or possibly a wheel is bent a little. In my case, my 40-50 mph shimmy is coming from two bent steel wheels.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is online now
post #3 of 7 Old 06-24-2003, 02:06 PM
kaybone
clean off all the gunk on your wheels inside
and out. Have your tires rebalanced. If problem
is still there, rotate fronts to backs and see
if problem is less. I did this and problem
totally went away.
kaybone is offline
post #4 of 7 Old 06-24-2003, 10:23 PM
macb
macb's Avatar
ditto...probably just a balance issue - I have twice thrown a weight when offroad. - they get scraped off on the rocks.
always remember - it is a good idea to do a 'routine check' of the under carriage after any offroading trip.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #5 of 7 Old 06-25-2003, 08:48 AM Thread Starter
rsant39
thanks for the suggestions. it is probably a balance issue. i had my tires rotated at the dealership recently and maybe they forgot to balance them after they rotated them.
rsant39 is offline
post #6 of 7 Old 06-25-2003, 08:55 AM
macb
macb's Avatar
my wife had hers balanced at the stealership 4 weeks ago (Jeep Cherokee)...came back from vacation and 3 of the tires had thrown weights...damn stealerships
Bob Supplee:
or (405) 799-8977
macb is offline
post #7 of 7 Old 08-11-2012, 04:29 PM
Bruce06Unltd
Were you vacationing in Baja?
Bruce06Unltd is offline
Steering Wheel Shimmy at 45 mph after 2" Budget Boost. Suggestions? hddeuce TJ Wrangler Technical Forum 2 11-14-2009 09:39 PM
steering wheel shimmy when going over bumps rmb2485 TJ Wrangler Technical Forum 13 07-31-2007 05:39 PM
Wobble . Shimmy in Steering Wheel at 40-50MPH? fourtwenty TJ Wrangler Technical Forum 8 05-28-2007 06:14 AM
Help with Steering Wheel "Shimmy" at 35mph warner41 TJ Wrangler Technical Forum 2 06-08-2006 11:18 PM
Wheel shimmy farmboy1976 YJ Wrangler Technical Forum 3 04-19-2005 08:38 AM
