-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   steering wheel shimmy (http://www.jeepforum.com/forum/f9/steering-wheel-shimmy-42401/)
rsant39 06-23-2003 03:21 PM
I recently noticed that when I am doing 55mph my steering wheel shimmies a little. At lower and higher speeds the shimmy does not exist. Anyone know what could be causing this? Thanks
Jerry Bransford 06-23-2003 04:14 PM
It's not likely an alignment issue. Most likely a tire is simply out of balance. Or less likely, maybe either a little mud is stuck inside a wheel throwing it out of balance or possibly a wheel is bent a little. In my case, my 40-50 mph shimmy is coming from two bent steel wheels. :D
kaybone 06-24-2003 02:06 PM
clean off all the gunk on your wheels inside
and out. Have your tires rebalanced. If problem
is still there, rotate fronts to backs and see
if problem is less. I did this and problem
totally went away.
macb 06-24-2003 10:23 PM
ditto...probably just a balance issue - I have twice thrown a weight when offroad. - they get scraped off on the rocks.
always remember - it is a good idea to do a 'routine check' of the under carriage after any offroading trip.
rsant39 06-25-2003 08:48 AM
thanks for the suggestions. it is probably a balance issue. i had my tires rotated at the dealership recently and maybe they forgot to balance them after they rotated them.
macb 06-25-2003 08:55 AM
my wife had hers balanced at the stealership 4 weeks ago (Jeep Cherokee)...came back from vacation and 3 of the tires had thrown weights...damn stealerships http://sajeeps.billmcgaw.com/images/pirate.gif
Bruce06Unltd 08-11-2012 04:29 PM
Were you vacationing in Baja?:2thumbsup:
The time now is 05:03 PM.
