steering wheel shakes when I turn - JeepForum.com
post #1 of 4 Old 04-06-2003, 12:25 PM Thread Starter
Ned97sahara
When I make a slow turn the steering wheel jumps as if it were in four wheel drive. It doesn't shake as bad as if it were in four wheel drive but the wheel makes the same jerking motion very slightly. I can't figure out what the problem is. Did anybody ever have this problem?
Thanks
Ned
2007 Ford Ranger 4x4 4.0L auto ( I know it's not a jeep but untill I buy my wife a house this is all I am going to have) Future mods: AEV bridgers and some 32's:)
1st jeep:98 TJ sport w/4 inch lift and 33's (wrecked)
2nd jeep:97 TJ sahara locked and loaded w/7" of lift and 35's (sold for WJ)
3rd jeep:2004 grand cherokee WJ special edition
W/MTR 245/75/R16's (sold for 07 Ranger)
Ned97sahara is offline
post #2 of 4 Old 04-06-2003, 12:31 PM
Owen
Owen's Avatar
Re: steering wheel shakes when I turn
Thanks
Ned
Sounds like it could be a lot of things. Do you have a dropped pitman arm? A dropped pitman arm can cause bumpsteer. Which I am assuming is what you have.
Check all the bolts on the front end to make sure they are tight. Especially the trackbar...HTH
Smuggler Re-Born.....
Owen is offline
post #3 of 4 Old 04-06-2003, 02:52 PM Thread Starter
Ned97sahara
Can you get bumpsteer on a stock TJ? The only thing I have done to it is put 31's on it and it seemed to start when I took my hard top and full steel doors off. At least I didn't notice it until then. Everything seems tight in the steering. Is it possible that my hubs are engaging sometimes when not in 4 wheel drive?
post #4 of 4 Old 04-06-2003, 06:52 PM
young yeller
young yeller's Avatar
How many miles have you put on the 31s since you last rotated them? Although it's not necessary to rotate them every 5 grand, it's pretty important once you hit 10 or so.
Once the front tires start cupping they'll cause the steering wheel to vibrate a little, sometimes mistaken for bumpsteer.
2001 TJ Sport-Yellow l 4.0L/5sp
Yellow Jeep Club Member #5
young yeller is offline
steering wheel shakes up and down during take off? bustedtj TJ Wrangler Technical Forum 3 01-31-2010 09:15 AM
around 50+ steering wheel violently shakes a lil and everything vibrates plus more... Mitchin TJ Wrangler Technical Forum 20 01-15-2010 12:32 AM
Steering wheel shakes at 45 MPH BaldHeadedDawg TJ Wrangler Technical Forum 3 05-01-2009 02:43 PM
Steering wheel shakes agraywall TJ Wrangler Technical Forum 4 02-12-2008 09:41 AM
Odd steering wheel shakes issue... TheAdjuster TJ Wrangler Technical Forum 0 07-22-2004 12:05 PM
