Steering wheel hard to turn - JeepForum.com
post #1 of 8 Old 10-25-2005, 10:47 AM Thread Starter
samger2
I have a 97 TJ, on cold mornings right after I start the Jeep the steering wheel is really hard to turn, almost like there's no power steering, but then after a few inches, gives way and turns easily, this happens about until I get to the end of the street and then goes away, but it only happens in the fall and winter time. Is this common? What causes this? Thanks,
Sam
samger2 is offline
post #2 of 8 Old 10-25-2005, 11:06 AM
jeep_chinto
have you checked ur power steering fluid lvl?
iv never had the issue... if i did i didnt think any thing of it because i was probably in 2+ feet of snow.
possably empty out the power steering fluid and fill it with new?
there is also a oil company that makes power steering "oil" for lack of a better word that is made to renew seals and what ever else in the pump i for get the name of it ia ctually have it sittin next to my computer at home used it on my evo when the power steering pump was on its way out.. didnt help but it was to late..
think its called lucas oil? but they make spacific ones for all differnt things.
good luck.
jeep_chinto is offline
post #3 of 8 Old 10-25-2005, 11:18 AM Thread Starter
samger2
Thanks for the tips, I'll check the fluid.
Sam
samger2 is offline
post #4 of 8 Old 10-25-2005, 04:36 PM
Clank
I have a similar problem. If I park in the garage where itís warm nothing happens. If I park outside on a cold morning it whines when I make turns. It sounds like it is coming from the inside, but quits when the Jeep warms up.
99 TJ
4" Pro Comp lift with body lift
35" tires
Skid Row NightCrawler Bumper
Warn 8000 winch
Clank is offline
post #5 of 8 Old 10-25-2005, 05:05 PM
JoonHoss
2011 JK Wrangler
do you mean like this?
http://www.jeepforum.com/forum/f9/moaning-when-turning-steering-wheel-203073/
"three gallons of low lead; two hot dogs and a strawberry soda..."
JoonHoss is offline
post #6 of 8 Old 10-25-2005, 08:43 PM
ncb76
ncb76's Avatar
Mine does the same thing. Try bumping up the RPM's and see if it goes away. If it does, then it's probably the pump.
I think my pump is bad. The problem started after I was doing donuts in a snow covered parking lot. I probably overheated it by keeping it turned against the steering stops.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #7 of 8 Old 10-25-2005, 08:43 PM
Clank
Exactly what wyldejackyl said. It did it today after work, but as soon as it warmed up it stopped. I guess the Jeep likes to be it the garage.
99 TJ
35" tires
Warn 8000 winch
Clank is offline
post #8 of 8 Old 10-25-2005, 08:48 PM
Clank
I don't think it's the pump. My truck had a bad pump before. The noise came from the engine compartment then. Had to replaced the pump, that was fun.
99 TJ
35" tires
Warn 8000 winch
Clank is offline
Noise when I turn my steering wheel... TJ-Tera TJ Wrangler Technical Forum 5 01-27-2008 06:53 PM
weird noise when i turn the wheel hard to left or right...what is it? itsgroll YJ Wrangler Technical Forum 20 12-23-2007 11:28 PM
Wheel hubs: how hard to turn by hand? Fett TJ Wrangler Technical Forum 8 05-15-2006 01:01 PM
Steering wheel won't turn CityJeep90 YJ Wrangler Technical Forum 3 05-19-2005 07:50 AM
Steering wheel squeak and hard turn hummer YJ Wrangler Technical Forum 4 08-16-2002 05:53 PM
