Steering upgrade question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Steering upgrade question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-26-2015, 02:57 PM   #1
mlamb1231
So a little over a year ago I put a 3in. Zone lift on my 03 TJ. the handling was never all that great afterwards, as I expected anyways, but lately its gotten much worse and since I have the money now I figured I would upgrade the control arms and the drag link/tie rod set up.
I've already ordered some MC Duroflex CAs and so now I'm debating on the steering set up I want. My jeep is a daily driver but I do use it offroad quite a bit throughout the spring and summer. Now I have done quite a bit of research and everyone recommends the Currie set up, however it is pretty pricey and so I have also been considering the Crown kit as well.
Now obviously everyone would recommend the Currie set up, so my question isn't about which is recommended more. My question is is the Currie set up overkill for my jeep? or is it worth the extra $200 even though I don't plan on going any bigger than 33s in the near future? Is spending the extra $200 justified or is it just not necessary?
mlamb1231 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 03:09 PM   #2
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
The crown kit keeps the weak drag link.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 04:58 PM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
It had nothing to do with the Zone lift.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 05:01 PM   #4
Gary2
Had the Crown type for a couple months and have had the Currie for years since and yes with only 33s it is worth the extra few bucks and be done with steering .
Gary2 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 05:16 PM   #5
mlamb1231
Did the crown steering just not work well enough for you? What was your reason for switching?
Unread 03-26-2015, 05:19 PM   #6
mlamb1231
I never said it did. Sorry if that's what you thought I was implying. What I meant is that since I still have stock control arms and stock steering that raising it 3in messed with the handling.
Unread 03-26-2015, 05:30 PM   #7
Gary2
At first it seemed OK but after running it for a little while I realized it didn't feel much if any different than the OE set up with 50 some thousand miles on it . I had Currie on my previous Jeep that was about 6 years old before I bought the Jeep and that felt tighter than the zj did . I know what felt the best so I bought it and have been happy again
Unread 03-26-2015, 05:32 PM   #8
mlamb1231
Great that helps a lot. Looks like I'll go with Currie. Thank you
Unread 03-26-2015, 10:11 PM   #9
joe_jeep
The currie setup is sweet! If u can afford it, its the way to go!
I could not afford it at the moment, but will pretty soon.
To hold me over, I got a complete zj setup off ebay.
Every part, 2 outer tie rods, 2 adjuster sleeves, drag link, and tie rod.
$80.42 shipped to my door. It will make a great trail spare when I get the currie stuff.
I used the same thing on my first tj for years without issue.
It made my post lift alignment go much easier with brand new parts!
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 12:45 AM   #10
_KONG_
Just get a ZJ tie rod
_KONG_ is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 05:10 AM   #11
RnEmOvr
RnEmOvr's Avatar
Why? The drag link it the weak link in stock setup.
Unread 03-27-2015, 07:06 AM   #12
rouxbicon
Sure about that? On a TJ, it's the tie rod that is hollow tube, right? The drag link is solid, and not nearly as much of a weak link as the tie rod is.
'03 red Rubi
rouxbicon is online now   Reply With Quote Quick reply to this message
Unread 03-27-2015, 07:15 AM   #13
mdm
Farm Wheeler
...raising it 3in messed with the handling.
How? What is it doing?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 08:27 AM   #14
05x
Im running Currie its night and day well worth it if you go that route
05x is offline   Reply With Quote Quick reply to this message
Unread 03-27-2015, 09:07 AM   #15
RnEmOvr
RnEmOvr's Avatar
According to Blaine it is.
steering , tj
