#1 | |
Steering upgrade... crossover?
I've been looking at steering upgrades for a while now. My tie rod driver's end is loose and the joint where the tie rod and drag link meet is rubbing against the sway bar axle link. I was thinking of maybe going with crossover steering, but the ORO U-Turn is a bit too pricey for me, and the RK uses heim joints which I'm not too fond of due to bad opinions. The JCR looks attractive as well, but I don't like the thought of taking it somewhere to ream out my pitman arm and steering knuckle. I hear lots of good things about the Currie kit, but it's not crossover steering.
In the end I suppose I'm asking Crossover vs Currie HD
2000 TJ Sport, 3-speed slushbox HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s ORIGINAL Black Jeep Club Member #34 ThePointbreak.org | Mods and Wheeling pics |
#2 |
Does the currie have a bend at the swaybar mount? I cant remember and was thinking of the upgrade, but I've got some rubbing there also...
99 TJ Gone but not forgotten
04 Rubicon 6" Nth Degree LA, 35" MTRs on Allied Beadlocks, Monster air valves,4.88s, Nth Tummy Tucker, Diff Stingers, Engine and steering box skid, Poison Spyder front and rear Stingers, Crusher corners, Rocker Knockers, Steering box and Gas skids, Full cage, LED lights, Currie HD steering, Warn 9.5 Ti, Superior Shafts, CB, My Shafts a Woody, More motor mounts, CTM joints, SwayLoc, York Air And AiROCK on the way I wave... |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
Though my 4 year old Currie steering kit doesn't rub, Currie has been shipping a newer version for some time now that has a more pronounced bend to reduce, if not totally prevent possible rubbing. It's real hard to beat Currie's kit but then I know nothing about current cross-over kits.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 |
My Currie kit rubbed a bit, and I clearanced the bracketry on my LP30 where it rubbed with a grinder. On my HP30 it was a combination of control arm length (to move the axle front/back while setting caster) and some minor grinding also. Or if you have access to a big press, you can bend the drag link a bit more. Even with the tweaking, it's a mod I'll never regret.
98 TJ 4.0L | GenRight Stretch, 4 Link | Built XJ HP30 & XJ 44 | AW4 | ARB's | 35" Krawlers | Allied Beadlocks | York OBA | Warn 9500i etc. | M416 Trailer Kentucky Krawlers |
#5 |
TBT also makes a cross over steering system, more expensive but with all the bent tie rods out there the Alumi-Flex would be worth it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
