Steering Stabilizer Opinions/Experience - JeepForum.com
 4Likes
post #1 of 18 Old 10-16-2017, 01:42 PM Thread Starter
Reeljeep
I have a 99 TJ 4.0 A/T, It's that time again to replace my steering stabilzer again, 3inch lift on 33's I do a lot of Highway driving and aside from being squirlly becouse of the wheel base I was wondering if upgrading to a dual stabilizer would make a difference in my steering as it seems loose. My front end is good, tires are good also just want to have a little more feel of resistance at 55-70 mph.
Thanks
If your not living on the edge, your taking up to much space!
Reeljeep is offline
post #2 of 18 Old 10-16-2017, 01:49 PM
biffgnar
biffgnar's Avatar
Dual stabilizer always a bad idea. For almost all stabilizers there is very little difference. Buy a Monroe from the parts store and paint it your favorite color. If it doesn't "work", you have other issues in your front end.
Richisinyoface and coach-mike like this.
biffgnar is offline
post #3 of 18 Old 10-16-2017, 02:13 PM
coach-mike
I agree totally with the above. I bought a FOX 2.0 waste of money for a stabilizer
coach-mike is offline
post #4 of 18 Old 10-16-2017, 03:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Never install dual stabilzers on a TJ, they aren't needed and they just force the power steering system to have to work harder. Just a simple inexpensive hydraulic steering stabilizer like from Monroe, Rancho, etc. is all you need.
Jerry Bransford is online now
post #5 of 18 Old 10-16-2017, 04:11 PM
1longcj
A bigger bandaid won't fix the real issue. If setup correctly you could drive without one.
Jerry Bransford likes this.
1longcj is offline
post #6 of 18 Old 10-16-2017, 05:21 PM
hokahay
Hey, wait a minute!
I have one.
My OCD demands a stabilizer that matches my shocks. Otherwise, it looks half baked. LOL
Also, it could be that the fox has a better lifespan and performance same deal as the shocks.
On the other hand, a dual setup to try to fix stuff is a total system dump. To quote Murray on Riptide.
hokahay is offline
post #7 of 18 Old 10-16-2017, 11:10 PM
Poppy360
Poppy360's Avatar
I haven't driven with one for over a decade. No reason to.
Sent from my iPhone using Tapatalk
TJnBC likes this.
'98 TJ Sport 4.0L
RE 3.5" Long Arm w/ 1"BL; 35" KM2's; 8.8; HP30; 4.88's; Dual ARB's; Warn HS9500i; OME Shocks; CO2; Fully Armored; ORO U-Turn Steering; LoD Rear Bumper/Tire Carrier; Durango Steering Box; Heated Seats
Poppy360 is offline
post #8 of 18 Old Yesterday, 05:47 AM Thread Starter
Reeljeep
Ok, I remeber how much nicer it seemed after I replaced it a few years back, I guess mine just wore out over time and just needs to be replaced.
Reeljeep is offline
post #9 of 18 Old Yesterday, 07:34 AM
Ironhead
does your lift have adj control arms allowing to adjust caster?
Ironhead is offline
post #10 of 18 Old Yesterday, 11:02 AM
biffgnar
biffgnar's Avatar
While it should not be necessary to drive down the road steadily, it does serve a dampening service to reduce shocks transmitted to the rest of the front end. Front end consumables will wear faster without one.
biffgnar is offline
post #11 of 18 Old Yesterday, 11:31 AM
duck851
Originally Posted by hokahay View Post
Hey, wait a minute!
A Riptide reference....LMAO. My week is complete!
duck851 is offline
post #12 of 18 Old Yesterday, 11:57 AM
W33k3ndWarrior
Personally i love my rough country n2.0 stabilizer. It wasnt very expensive and it fixed the slight wobble in my front end.
W33k3ndWarrior is offline
post #13 of 18 Old Yesterday, 12:13 PM
Jerry Bransford
Administrator
No, it didn't fix the wobble. All replacing the SS did was to suppress the wobble so it's not as apparent but whatever was the root cause of the wobble is still there.
Steering stabilizers cannot cause wobble, shakes, shimmies, Death Wobble, etc. so replacing the SS is NEVER the fix for any of those. Replacing the SS to fix any of those is like placing a band-aid on a skin cancer. It won't be noticeable any more since you can't see the cancer but it's still there.
post #14 of 18 Old Yesterday, 05:26 PM
Shark_13
Thanks
What is your toe in and caster set to?
What is your tire pressure?
Also, how old are the tie rod ends on all steering components up front?
Shark_13 is online now
post #15 of 18 Old Yesterday, 05:31 PM
Richisinyoface
Richisinyoface's Avatar
I can't agree more.....
Just Empty Every Pocket.......yup they are empty all right.................
NRA Life member
Sienna Jeep club member #65
Richisinyoface is offline
