steering stabilizer needed? - JeepForum.com
post #1 of 26 Old 06-24-2008, 07:40 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
When i go 50-54 my jeep will shake once i hit a bump and some times just because i'm moving... it does it when i go faster, but not as much as 50-54mph ...
will a steering stabilizer help this? or what else is needed to be looked at?
does it while accelerating, idling, and braking... shakes the whole jeep, passengers feel it..
is this a small case of death wobble?
03Wrangler is offline
post #2 of 26 Old 06-24-2008, 07:58 PM
jaykudach
your jeep should have a stock stabilizer on it already- although it may be going bad...
my jeep started having the same issue when i put a 2" BB in. i think mostly do to an alignment issue.
Since having it aligned it still will wobble on occasion (more then before i modified the suspension) but not nearly as much or as severe.
it could possibly be a tire balance issue in the front as well.
have you made any suspension/ tire changes lately?
jaykudach is offline
post #3 of 26 Old 06-24-2008, 08:34 PM
ranger140892
A new stabilizer won't solve your problem. Look at: Wheel balance, loose and or worn steering and suspension components.
ranger140892 is offline
post #4 of 26 Old 06-24-2008, 08:43 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
i rotated my tires so that the fronts are now in the rear and visa versa, it did not help at all... no changes but the tire rotation, it was doing it prior...
think i should go get my tires re-balanced first?
post #5 of 26 Old 06-24-2008, 09:10 PM
BozoWise
BozoWise's Avatar
Is the suspension all stock? Has it always had this issue or started recently?
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #6 of 26 Old 06-25-2008, 06:36 AM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
suspension is all stock besides some napa shocks which i bought a little over a month ago...
it has only done it for the past 2 weeks....
post #7 of 26 Old 06-25-2008, 07:07 AM
BChamberlin
BChamberlin's Avatar
So what does a stearing stabilizer do then? If it doesn't improve anything... how do you know if the old stock one has gone bad? I'm not saying this is the culprit of the original posters problem... but it's a cheap upgrade so why not put it on? It's got to help a little.
2008 Wrangler X
BChamberlin is offline
post #8 of 26 Old 06-25-2008, 10:53 AM
ranger140892
It protects the steering gear from shock & damage. If you've got other problems, the stabilizer won't cure it.
If your suspension and steering components are in good order, you can run with no stabilizer and not get any wobble. Not advisable though.
post #9 of 26 Old 06-25-2008, 12:16 PM
BChamberlin
So I put a 2 inch lift and 32's... with a 1 mml and a 1.25 body lift... upgrading the stabilizer will do absolutely nothing??
2008 Wrangler X
post #10 of 26 Old 06-25-2008, 12:34 PM
ranger140892
Not exactly. If you're running large tires, an upgraded stabilizer WILL help reduce shock and wear in the steering gear box. It's just not going to stop any death wobble.
Death wobble is caused by faulty components downstream of the stabilizer.
post #11 of 26 Old 06-25-2008, 01:11 PM
BChamberlin
Any opinions on brand? I see Skyjacker, OME, and Rancho talked about a lot. I figured at $50 it's not a bad thing to swap out since I've got 150,000 miles and an original.
2008 Wrangler X
post #12 of 26 Old 06-25-2008, 01:16 PM
BozoWise
BozoWise's Avatar
If your all stock I think it is unlikely you have the death wobble issues that you see with lifts. Similar maybe, not the same.
The first thing I suggest is to remove the stabilzer itself or atleast one of the ends. Try and collapse and extend the stabilizer. As long as there is moderate resistance each way it is still good. Either way it will not cause the problem but a nice one can help to cover up the problem. Kinda like painting over rust.
If you have already swapped the wheels front to back and there was NO change then I doubt it is a tire issue. It never hurts to check balance often on the tires and many places will do it free, charge to fiz them if they are off. Watch and make sure they are actually removing the weights and installing new ones if they say it has to be done.
I would also check all the tie rod ends and ball joints. If you have one loose then that can cause these issues. I have also seen track bars come loose and cause the same effect. Get under there and do some twisting to check the joints. Grease everything up and put proper torque on all the joints and bolts. Make sure and check the control arm bolts also.
BozoWise is offline
post #13 of 26 Old 06-25-2008, 03:59 PM
flatlander757
Check the trackbar bolt at the axle, should be 55ft-lbs. It can appear fine but be loose enough to cause problems.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #14 of 26 Old 06-25-2008, 05:01 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
i was under there and nothing appeared to be loose...
i'll go take my tires to be balanced, and if that doesnt fix it, then i'll do the stabilizer check like mentioned above...
which is the trackbar?
post #15 of 26 Old 06-25-2008, 05:42 PM
ranger140892
"Appeared" don't get it. You can't see tight. Put wrenches to bolts. Preferably torque wrenches.
Track bars are the diagonal round bars that keep axle aligned under frame. Front goes from drivers side frame to passenger side axle. Rear is opposite.
HD Steering Stabilizer NEEDED with 35's? PSYCH0 JK Wrangler Technical Forum 20 10-12-2009 07:15 PM
Replace Steering Stabilizer - Alignment Needed? CosmosMariner TJ Wrangler Technical Forum 6 03-10-2009 11:21 PM
Steering stabilizer install help needed oif03vet TJ Wrangler Technical Forum 10 01-16-2009 12:09 PM
Dual Steering Stabilizer? Is It Really Needed? swsscb TJ Wrangler Technical Forum 10 05-14-2008 12:24 AM
New steering stabilizer needed - anything else I should get done? RockyIV TJ Wrangler Technical Forum 1 12-08-2004 03:45 PM
