Steering stabilizer attachment to steering link - JeepForum.com
post #1 of 9 Old 09-06-2007, 06:16 PM Thread Starter
Bill87GT
Is this just a press fit like the tie rod ends or is it threaded in? I'm guessing it's a press fit, but I have a ton of force on my press and it ain't budging. Got the swaybar end links off with a loud pop, but this one doesn't want to go. That's why I'm wondering if maybe it's threaded.
'99 Wrangler & '87 Mustang GT
'01 Blazer ZR2 - FOR SALE
Bill87GT is offline
post #2 of 9 Old 09-06-2007, 06:32 PM
EG00TJ
EG00TJ's Avatar
1993 XJ Cherokee
Not threaded... same as your end links.. it will eventually go..
96 ZJ Longarm
Previous rigs : 96xj , 92 xj , 00 tj , 90 xj , 93 Longarm XJ
EG00TJ is offline
post #3 of 9 Old 09-06-2007, 06:32 PM
Big-E
Not threaded. I had drill mine out.
Big-E
Louisiana
2000 Sport
Big-E is offline
post #4 of 9 Old 09-06-2007, 06:50 PM
luk4mud
I used a pickle fork- worked after a while, the thing kinda exploded when it came off.
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline
post #5 of 9 Old 09-06-2007, 07:08 PM
JeepRide
JeepRide's Avatar
just replaced my shimmey shock it was rusted stuck sprayed it with pb blaster for week didnt help a bit.I finally got out propane torch heat an beat then repeat it took a while but I finally got er did.
98 xj 4.0L 231 / aw4 /8.25/3.55
31x10.50 a/t 3 inch bastard lift
JeepRide is offline
post #6 of 9 Old 09-08-2007, 06:31 PM Thread Starter
Bill87GT
Heated her up with the propane torch and put the gear puller on it. Loud bang and the next thing I saw were all my tools on the ground. Unbelievable. Nothing needs to be THAT tight.
Bill87GT is offline
post #7 of 9 Old 09-08-2007, 07:49 PM
Dogman
Dogman's Avatar
Whack the side of the drag link with a small sledge, it will pop out after a few hits. The first time I pulled my steering apart I used a puller for the first few components, then switched to the hammer which was much easier
John 3:17
Dogman is offline
post #8 of 9 Old 09-08-2007, 07:49 PM
KnightFire
KnightFire's Avatar
Guess I got lucky with mine, came out with a just a few love taps from a hammer...no puller/pickle fork needed. I did have them handy just in case though...
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #9 of 9 Old 09-08-2007, 08:59 PM Thread Starter
Bill87GT
I always try that first since it's easiest. I think it's worked once in the 20 or so times I've had to disassemble joints such as this in my life.
Bill87GT is offline
Question about Steering Stabilizer after HD steering install. Hellbound13 JK Wrangler Technical Forum 2 07-14-2009 09:29 PM
Rock Krawler HD steering + steering stabilizer Giviner TJ Wrangler Technical Forum 1 05-03-2008 07:19 PM
K-Link Steering System or HIgh Steering for YJ 92YJer YJ Wrangler Technical Forum 2 02-12-2008 03:08 PM
Steering Knuckle is stripped @ lower caliber bolt attachment hole Jeepin088 TJ Wrangler Technical Forum 4 08-05-2007 07:16 PM
need pic of SOA d30 steering stabilizer attachment (not the tie rod part) bigstinger YJ Wrangler Technical Forum 6 07-09-2007 04:35 PM
