Quantcast Steering Stabilizer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Steering Stabilizer
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 01-27-2008, 08:03 PM   #1
TJeep97
Steering Stabilizer
ok so i have searched and searched on steering stabilizers. the OME is the one that i am hearing. is this a good steering stabilizer for my tj with 3.25 in lift with 33's. i am trying to stay in the 60$ range. any suggestions would be very helpful!!!
thanks alot and happy wheeling.
[SIZE="2"][FONT="Garamond"][CENTER]1997 Jeep Wrangler 2.5 liter 4 cylinder
2 inch budget boost 1.25 JKS BL
33X12.50X15 D-Mud Cragar Soft 8's Skyjacker SS[/CENTER][/FONT][/SIZE]
[CENTER][B][SIZE="3"]Sick Nasty Jeep Club Member #1[/SIZE][/B][/CENTER]
TJeep97 is offline   Reply With Quote
Old 01-27-2008, 08:04 PM   #2
nicolas-eric
i have the OME steering stabilizer and it works fine. much beter than the stock one.
+ such a yellow thing at the steering linkage looks good IMO.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Old 01-27-2008, 08:05 PM   #3
airframer
damn thats a lot 4 a stabilizer, i have the pro comp one it works just fine.
Everything in moderation
airframer is offline   Reply With Quote
Old 01-27-2008, 08:05 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
They're all pretty much the same 50:50 valved hydraulic shock. You can get a Rancho, Skyjacker, etc. for less than $60. Make sure it's specifically for a TJ as some kits are generic enough that they don't include the correcte tapered bolt for the driver's side end of the stabilizer.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 01-27-2008, 08:06 PM   #5
Q-01
I have 33s and went back with the stock replacement - works fine.
'99 2.5L, susp. lift, Lock-Rite in front, K&N intake, exhaust mod, 33x12.50 BFG A/Ts, 4.56 gears, sway bar disconnects, fuel tank mod, snorkel.
Q-01 is offline   Reply With Quote
Old 01-27-2008, 08:06 PM   #6
TJeep97
wheres a good place to purchase one. i usually shop quadratec
Old 01-27-2008, 08:09 PM   #7
Nevam
I'll be getting the OME steering stabilizer soon as I've only heard and read good things about it. The only "negative" I've seen is the price. You can check out a couple others in the review section of the forum:
http://reviews.jeepforum.com/showcat.php?cat=63
Current Jeeps in the household:
'03 TJ Rubicon
Past Jeeps:
'95 ZJ Laredo - '98 ZJ Limited - '01 WJ Limited
'06 TJ Rubicon - '89 YJ Islander
- '01 TJ Sahara
'98 TJ SE
Nevam is offline   Reply With Quote
Old 01-27-2008, 08:16 PM   #8
Jerry Bransford
Quadratrac is the most expensive source of Jeep parts around and they don't even support Jeep Forum like our vendors do. I wouldn't pay more for an OME stabilizer, they're no better than the others mentioned. OME's stabilizer is a 50:50 valved hydraulic shock just like the rest of them are, not gas charged like their shocks are.
Getting Savvy...
Old 01-27-2008, 08:19 PM   #9
TJeep97
what would you suggest then.
thanks for the help by the way
Old 01-27-2008, 08:31 PM   #10
Jerry Bransford
Rancho and Skyjacker are both good and easy to find. Rubicon Express is fine too, they're likely made by the same company which is probably Monroe. These are all pretty much the same, even ProComp's are the same shock internally but they apparently don't last quite as long as the others due to their lower quality chrome on the strut and paint on the shock body.
Getting Savvy...
Old 01-27-2008, 08:31 PM   #11
Mike
no radiator req'd
Mike's Avatar
Monroe-NAPA-$23
Originally Posted by Grape Ape View Post
I forgot he has the Seabee thing going for him. Wimminz can't resist the Seabees we are just that damn awesome.
Mike is offline   Reply With Quote
Old 01-27-2008, 09:04 PM   #12
TJeep97
ok thanks.
Old 01-27-2008, 09:24 PM   #13
BlueJ
Looking back I bought mine for the name and color and that is it. There was no need for it over the cheaper ones.
2000 TJ - Patriot Blue
Same stuff as most of ya got. =)
BlueJ is offline   Reply With Quote
Old 01-27-2008, 09:32 PM   #14
Yellow TJ
I got to tell you, I had my original one for 5 years....I have had my pro comp one for about 9 months and am ready to replace it again. I will not be replacing it with another pro comp for sure.
Yellow TJ is offline   Reply With Quote
Old 01-27-2008, 09:43 PM   #15
Wup This
My ProComp is already rusting and it got put on in LATE NOVEMBER....I will be replacing it soon with a RE or Rancho. I got it for free so I am not complaining. All the other ProComp stuff I have is holding up to the salty roads perfectly.
98 XJ, Pearl Green, 4.5" lift, 32's Daily Driven. BEAT IT! BREAK IT! FIX IT!
Wup This is offline   Reply With Quote
Glock Forum
