Steering stabilizer - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Steering stabilizer
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-26-2014, 11:21 AM   #1
Jvod
Steering stabilizer
I've been in the process of fixing "death wobble". I put a stock stabilizer on about a year and a half ago, and the wobble came back. Was told I should invest in a nicer one. Any recommendations on brands (theres a lot to choose from and a little overwhelming), and whether a 'dual' one is worth the extra money. Thanks.
Jvod is offline   Reply With Quote
Unread 08-26-2014, 11:24 AM   #2
MarkNog
If its only a year and a half old, I would look toward other things that could be causing it. Also, I would not waste my time with a dual stabilizer, it is just masking the real problem.
MarkNog is offline   Reply With Quote
Unread 08-26-2014, 11:25 AM   #3
allhaileris
Everybody will tell you that the stabilizer is not the problem. The stabilizer works to hide the problem.
I found this helpful. Others may, or may not.
allhaileris is offline   Reply With Quote
Unread 08-26-2014, 11:25 AM   #4
Ironhead
if the stabilizer is bad, its do to worn components in your steering. a new one will have the same short life.
dont run duals
Ironhead is offline   Reply With Quote
Unread 08-26-2014, 11:40 AM   #5
Muddeprived
Who told you that?
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Unread 08-26-2014, 12:02 PM   #6
Jvod
I was parked by a construction site one dayand just got to talking with a guy that had an 2007 (mine is a 2006). He said he had the same problem and showed me his stabilizer. He wasn't trying to sell me anything, was just giving his advice.
Unread 08-26-2014, 12:06 PM   #7
Neil F.
Incorrect advice.
Neil F. is online now   Reply With Quote
Unread 08-26-2014, 12:07 PM   #8
BigRodney
You need to check all your front axle components for wear and tires for balance. Ball joints, tie rod ends, unit bearings, track bar bushings, everything.
BigRodney is offline   Reply With Quote
Unread 08-26-2014, 12:17 PM   #9
Jvod
Just got my tires balanced and it seemed to help, but obviously did not fix the whole problem. Everything I've read about it I've done my best to check. Loose bolts, exposed metal, and loose components. Just figured this might be something else to help. Figured buying a nice part instead of something from advanced auto can't hurt. If you haven't noticed by now my knowledge is very limited, just trying to learn as I go. I do appreciate everyone's responses
Unread 08-26-2014, 12:20 PM   #10
Ironhead
on a properly functioning system, you can remove your steering stabilizer and not notice a difference
Unread 08-26-2014, 12:42 PM   #11
tj_john
Junior Member
tj_john's Avatar
This^
I ran mine for a few months without a stabilizer and didn't have any issues.
Try jacking up one side of the Jeep and wiggling the tire. Look for any movement and examine the part. Repeat on the other side. Next, try starting it up and have a helper turn the wheel back and forth. Look for parts that have play.
tj_john is online now   Reply With Quote
Unread 08-26-2014, 01:10 PM   #12
Schnervel
I haven't run a stabilizer for the last 4 years, just the Rock Krawler High Steer and Heavy-Duty Tie Rod:
Schnervel is offline   Reply With Quote
Unread 08-26-2014, 04:16 PM   #13
aparke4
aparke4's Avatar
Dual are not needed.
I have been running a steering stabilizer from PSC. It's the best! 😊
aparke4 is online now   Reply With Quote
Unread 08-26-2014, 05:26 PM   #14
crazyracer77
The 03 tj I just bought has dual stabilizers. Just had it inspected and will be doing my own inspection this weekend at my dad's house, he has a lift. You guys think I should take one off?
4 inch lift, 33's. 70k
crazyracer77 is offline   Reply With Quote
Unread 08-26-2014, 05:44 PM   #15
Ironhead
dual stabilizers put added strain on your steering box, i wouldnt run both
