steering stabilizer - JeepForum.com
post #1 of 11 Old 03-30-2010, 04:09 PM Thread Starter
bigskydrift
steering stabilizer
sooooo, I am trying to take the steering stabilizer / dampner off of my 97 TJ. Got the upper end off no problem but the other end that attaches to the drag link will not budge. I took the cotter pin out, got the nut off but cannot get the darn bolt to come out of the drag link....I soaked it in penetrating oil, have tried tapping it out with a hammer....it is like it is welded in there!
any ideas??
bigskydrift is offline
post #2 of 11 Old 03-30-2010, 04:13 PM
biffgnar
biffgnar's Avatar
Bolt is tapered. This subject comes up almost daily. Do a search. Multiple options. I think best is using a pitman arm puller.
Romney in 2020!
biffgnar is offline
post #3 of 11 Old 03-30-2010, 04:23 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I got a "loaner" pitman arm puller from Advance auto.It popped off in 30 seconds.
TheBoogieman is offline
post #4 of 11 Old 03-30-2010, 04:35 PM
SilverJ
SilverJ's Avatar
Hit it harder it will come out! I do not hit the bolt part, I hit the arm that encompasses the bolt. I hit it really hard and it eventually pops out without a puller.
SilverJ is offline
post #5 of 11 Old 03-30-2010, 05:02 PM
Holm-z
Holm-z's Avatar
I ended up using a torch and heating up the bolt and area around it. Poured some water on it after and hit it about 4 times with a hammer and it came right out. Its tapered not threaded in there so you can hit it out. My stabilizer came with new hardware for that end so i wasn't worried about damaging the bolt.
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #6 of 11 Old 03-30-2010, 05:50 PM
Disconnect
That sounds like the exact definition of excessive force Esp compared to a puller.. (Did mine last week. Puller takes about as long as hitting it twice with a hammer, without having to wave a hammer around your undercarriage and/or face..)
Disconnect is offline
post #7 of 11 Old 03-30-2010, 06:21 PM
Vandano
That does sound excessive, where you hitting the bolt with a hammer or where the tapered bolt sits. Normally you just hit the round portion that holds the tapered bolt on its edge and it causes it to pop right out.
Originally Posted by never monday View Post
when life gives you lemons.....make a trail rig out of it.
Vandano is offline
post #8 of 11 Old 03-30-2010, 07:13 PM
2003X
I had the same problem, the bolt would not bulged, get the puller, it came right off with it.
My Build
2003X is offline
post #9 of 11 Old 03-30-2010, 10:42 PM
Holm-z
Holm-z's Avatar
Yeah i know, my garage is 30 miles from the closest auto store and i happen to have a propane torch handy... It didn't take to long really.
3.75" RC
Superwinch 10000lb
I understand.
IAFF Local 3265
Holm-z is offline
post #10 of 11 Old 03-31-2010, 11:34 AM
bige2533
If there's a will, there's a way. However, if you can get a hold of a puller you'll be very happy you did.
bige2533 is offline
post #11 of 11 Old 03-31-2010, 01:15 PM Thread Starter
bigskydrift
thanks all, for the advice. I did end up buying a smal pitman arm puller, 8-10 turns and BANG, it was off!
steering stabilizer Janfri YJ Wrangler Technical Forum 17 11-25-2009 09:43 PM
Question about Steering Stabilizer after HD steering install. Hellbound13 JK Wrangler Technical Forum 2 07-14-2009 10:29 PM
Rock Krawler HD steering + steering stabilizer Giviner TJ Wrangler Technical Forum 1 05-03-2008 08:19 PM
Steering stabilizer attachment to steering link Bill87GT TJ Wrangler Technical Forum 8 09-08-2007 09:59 PM
What steering stabilizer should I get? T0DD YJ Wrangler Technical Forum 5 09-23-2003 10:44 AM
