Steering Shimmy and Wandering - JeepForum.com
post #1 of 18 Old 11-09-2009, 08:49 PM Thread Starter
Billyjon1
Just like the title says, thats my problem. Shimmy at around 40MPH, Jeep begins to wander at 50.
Things that have been done in past 6 months...
New Rotors
New Pads
Tires Balanced x2
Aligned x2
New Ball Joints(Uppers and Lowers)
New Tie Rod Ends(Inners and Outers... including $120 drag link)
New Hubs
All suspension components cranked down and checked twice.
Tires Rotated
It's not a huge problem, it's definitely tolerable, would just like to know if anyone else has any other suggestions I have not tried. I understand that with short, unadjustable control arms, the front axle is pulled backwards giving messed up caster angles that can lead to my symptoms(especially since I have 6 inces of lift in the front with 4 inch lower CAs and STOCK uppers). I DO plan on converting to a fully adjustable high clearance long arm kit within the next few months so please no harsh criticism lol.
2000 Wrangler: 351W/NP435/NP231 with HP44/9" combo
351 Swap:
Billyjon1 is offline
post #2 of 18 Old 11-09-2009, 08:51 PM
Imped
Imped's Avatar
Your caster is likely very crappy. Get adjustable arms so you can pull it into spec and try again. And a little bit of wander towards the low side of the road is normal and is accentuated with some tires.
OlllllllO
IndyORV
Imped is online now
post #3 of 18 Old 11-09-2009, 08:56 PM Thread Starter
Billyjon1
Yea that's what I figured, but it's weird because I've had the tires for close to two years now and they have worn excellently(I would definitely recommend Baja Claws to anyone looking for a new set of tires), and this wandering problem has seemed to just come up recently
351 Swap:
post #4 of 18 Old 11-09-2009, 09:01 PM
Imped
Imped's Avatar
Rotate them. And in that case, it 'might' be a tire problem. Or you're just now noticing it. Either way, with that kind of height, you could probably use some adjustable arms....and why not remove the 2" spacers in the front? That's a lot of height regardless of tire size. And I see you're from Cocoa Beach. Know Scott Nealon by chance?
OlllllllO
IndyORV
Imped is online now
post #5 of 18 Old 11-09-2009, 09:01 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yup, caster is the likely culprit. you won't notice any tire wear issues with caster, just with camber and toe.
when they balance the tires, make sure they ROAD FORCE BALANCE them. a one sided static balance won't gain you much.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 18 Old 11-11-2009, 09:07 AM Thread Starter
Billyjon1
I got the spacers because I like the "bulldog" look, one of my buddies did it on his Cherokee and it looked great. Like I said earlier though, it doesn't drive too bad, I drive it two hours everyday back and forth to school. The name sounds familiar, but I can't put a face to it right now.
And about the road force balance I have searched high and low for a place that does it around here and I was lucky enough to find the ONE place within 20 miles who would just do conventional balancing on 35's, which I can't believe seeing as how many new trucks and SUVs are coming STOCK with tires close to that size!!
Thanks for the help though!
351 Swap:
post #7 of 18 Old 11-11-2009, 09:11 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Enter your zip at the link below and it will tell you probably 25-50 shops within 10 miles of you that have a road force balancing machine.
Hunter GSP9700 Wheel Vibration Control System
Wheelin98TJ is offline
post #8 of 18 Old 11-11-2009, 09:55 AM
Max-Q
1983 CJ7
Thanks for the link. Lucky for me my friend and fellow Jeeper is the manager at one of the places that has the machine.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #9 of 18 Old 11-11-2009, 11:19 AM
jeffb_79
Getting your tires balanced probably won't fix your wandering issues.
Did you get the jeep aligned after you replaced the ball joints?
If not, your caster is probably way off. My caster read 5* before I replaced my shot ball joints. Afterwards it was at 3* and would wander all over the place.. to the point that I couldn't take my eyes off the road and changing lanes was dangerous.
I'd be willing to bet you're also getting pretty good driveline vibes above 50mph.
Get underneath and re-adjust your pinion angle. Your caster should be close to where it's supposed to be afterwards.
jeffb_79 is offline
post #10 of 18 Old 11-11-2009, 12:07 PM Thread Starter
Billyjon1
I have free alignments for the next 3 years so I get one whenever I mess around with that stuff and no vibes, I think it's probably the fact that the CAs are too small for my lift
351 Swap:
post #11 of 18 Old 11-11-2009, 04:30 PM
jeffb_79
OK... so what was you caster on the last alignment?
jeffb_79 is offline
post #12 of 18 Old 12-21-2009, 02:02 AM
UnderTheWooDd
Isn't Caster Adjustment pretty irrelevant being that the Knuckle Arms ARE WELDED TO THE AXLE HOUSING!!!!!?????
UnderTheWooDd is offline
post #13 of 18 Old 12-21-2009, 06:43 AM
jeffb_79
Um..... that's what adjustable control arms are for.
jeffb_79 is offline
post #14 of 18 Old 12-21-2009, 06:44 AM
jeffb_79
Or caster bolts if you don't want to get adjustable arms.
jeffb_79 is offline
post #15 of 18 Old 12-21-2009, 06:59 AM
Imped
Imped's Avatar
I think you may be referring to camber. That's not adjustable, at least easily. Caster is adjusted by rotating the axle housing around itself (think Z axis).
OlllllllO
IndyORV
Imped is online now
TJ Steering Problem--Wandering All Over the Road!! Snowman01TJ TJ Wrangler Technical Forum 27 10-10-2010 12:37 AM
Steering feels like it's wandering a bit rwmjeepjk JK Wrangler Technical Forum 4 02-10-2009 06:23 PM
Wandering Steering tx-Skydiver TJ Wrangler Technical Forum 6 12-29-2006 12:54 PM
Help with steering shimmy WenieD TJ Wrangler Technical Forum 0 10-04-2006 03:59 PM
Steering shimmy Jeepin' Rock Cl TJ Wrangler Technical Forum 8 03-31-2005 04:08 PM
