Steering shimmy - JeepForum.com
post #1 of 9 Old 03-31-2005, 10:57 AM Thread Starter
Jeepin' Rock Cl
Steering shimmy
My steering wheel shakes (rotates) back and forth about 1/2 inch, but only at speeds between about 40 and 55 mph. Unfortunately alot of my driving is in that range. What on earth can it be?
33" Kuhmo venture tires. I rotated and balanced last week, no effect.
Tightened track bar bolt. No effect.
Any ideas / things to check?
TIA!
Jeepin' Rock Cl is offline
post #2 of 9 Old 03-31-2005, 11:02 AM
brandongrover
Welcome to the club, had mine for the last month and half. If you find an answer let me know.
Black Jeep Member #333
2004 Sport
3.5" BDS w/ 1"MORE MML and 1" BL
Looks like a beast drives like crap, working on it...
Running Big Waylon's Old Gear Member #1
brandongrover is offline
post #3 of 9 Old 03-31-2005, 11:08 AM
doublins
check your caster angle. If it is inappropriately shallow, then correct with longer(adjustable) lower control arms in the front. Fix it while it's just a nuisance and before it worsens into death wobble.
-Chris
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #4 of 9 Old 03-31-2005, 11:14 AM
RockRunner85
Hate to break it to ya but I've been dealing with that for 10k miles. It goes away and comes. Normally its just a slight shimmy between 45-55. My tires are in perfect balance, toe and caster are right on. I do have the stock steering and track bar and an aftermarket monroe steering damper. I have a feeling the larger tires put more force on the trackbar bushing than it can handle stock. When I get some cash thats what I'm going to replace next.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #5 of 9 Old 03-31-2005, 01:01 PM
TJ_with_Tusks
do you have heavy duty steering shock? Also if you have a dropped pitman arm, and not very much lift, that can cause some vibs and wobble.
I figured this out the hard way
JerseyDan
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline
post #6 of 9 Old 03-31-2005, 01:27 PM Thread Starter
Jeepin' Rock Cl
I have a ZJ tie rod, stock everything else incl. pitman arm.
Maybe I'll have to look into a new track bar.
I did have a loose lower control arm bolt a month or so back, I wonder if it let the arm move enough to get things out of funk.
post #7 of 9 Old 03-31-2005, 02:32 PM
RockRunner85
I have the stock pitman arm also. The lower control arms have a washer that keeps them center in the slot. You can use ecentric washers to adjust caster or go with adjustale control arms (which is the recommend method as the washers can move out of adjustment).
post #8 of 9 Old 03-31-2005, 03:54 PM
greenmachine99
greenmachine99's Avatar
I'd check that out. Torque all steering componets to spec. Are you SURE your tires are balanced?
greenmachine99 is offline
post #9 of 9 Old 03-31-2005, 04:08 PM
RockRunner85
I know mine are defiantly balanced. I've had them done a couple of times over the past 10k at different places. Each place I watch them balance them to 0 and its always the same wqith the steeringwheel.
steering wheel shimmy rsant39 TJ Wrangler Technical Forum 6 08-11-2012 04:29 PM
yet another steering shimmy. what to do now? bow_hunter8 TJ Wrangler Technical Forum 7 02-09-2010 04:32 PM
Steering Shimmy and Wandering Billyjon1 TJ Wrangler Technical Forum 17 12-22-2009 06:19 AM
steering column shimmy cragrat TJ Wrangler Technical Forum 0 11-20-2007 07:15 PM
Help with steering shimmy WenieD TJ Wrangler Technical Forum 0 10-04-2006 03:59 PM
