steering mystery! - JeepForum.com
post #1 of 1 Old 10-27-2010, 10:43 AM Thread Starter
tj_steve
steering mystery!
if I open the reservoir cap after driving, should there be air escaping from high pressure inside the system, air entering due to low pressure inside the system (sort of like a vacuum inside), or nothing noticeable due to the pressure release valve. When I open the cap now, air is rushing in--I am pretty sure there should be no pressure there.
I am having a problem with my steering slipping sometimes when driving, and play in the wheel when turned, and steering not tight like it used to be. I now turn the wheel around almost twice to turn around a 45 degree corner when it used to take less than one turn. A new gearbox was just put on to fix these problems, and the problems still there, but a little less. Now there is a clicking sound when I turn the wheel that was never there. I believe that whatever caused the 1st gearbox to go will cause the new one to go. I have been associating this problem with a ditch I hit, but maybe it is something else that is happening that is causing the issue.
tj_steve is offline
steering box
Mystery steering issue - - - replaced gear box Supacheef TJ Wrangler Technical Forum 5 01-12-2010 07:22 PM
D44 Mystery MikeRi24 TJ Wrangler Technical Forum 10 02-22-2009 11:23 AM
Mystery LED Jetmech143 TJ Wrangler Technical Forum 8 07-08-2006 07:32 PM
mystery pop Polaris TJ Wrangler Technical Forum 4 07-03-2006 07:40 PM
Yj mystery..... 4x4punk YJ Wrangler Technical Forum 11 11-03-2004 07:42 AM
