steering at low speeds wheel jerks - JeepForum.com
post #1 of 15 Old 04-11-2009, 10:33 AM Thread Starter
pete1182
Ive got what feels to be power steering problem.When i turn the wheel at slow speeds the steering wheel jerks when turning almost feels like it in 4wheel drive.I turn the wheel at a dead stop and i dont get that feeling.ive tried taking it in and out of fwd a couple of times did not work and ideas thanks.at cruiseing speed i dont feel it as much.
pete1182 is offline
post #2 of 15 Old 04-11-2009, 11:01 AM
Duck Dodgers
Duck Dodgers's Avatar
Location: Somewhere between the Port of Indecision and South of Disorder
Have you checked you fluid level?
God grant me the serenity to accept the impossible trails I cannot crawl, courage to crawl the twisted trails I can, and the wisdom to keep the rubber side down.
Duck Dodgers is offline
post #3 of 15 Old 04-11-2009, 01:03 PM
SavannahJeep
I had what sounds to be this same issue in my 1999 Jeep Laredo about 2 months ago. I'm a car dealer and have excellent service guys that work for me. I had just replaced the transfer case to find that I had this issue lined up right behind it. My service guys told me it was my in my fronts and rears (didn't diagnose which at that point...I sold the car at auction). Does it only happen when you turn the wheel really sharp, or sometimes worse in reverse than forward? I will do my best to find out more about this in the meantime. Message me back with the actual details on when and how it happens when your driving.
There's still some pizza left in that box.
SavannahJeep is offline
post #4 of 15 Old 04-12-2009, 12:23 AM
PutPut
One or both of the u-joints in your front axles are probably dried out and starting to bind.
2000 TJ Sport, Yellow, BFG AT KO, 235K miles and counting.
PutPut is offline
post #5 of 15 Old 04-13-2009, 08:27 AM
SavannahJeep
Don't think its the u-joints. They make a noticeable clicking noise when turning at any speed and won't create steering jerks that were described as feeling like its in 4x4.
post #6 of 15 Old 12-11-2012, 08:25 PM
tjstevo
wen i put my jeep in fwd it sounds like its ticking what would be the cause of this
tjstevo is offline
post #7 of 15 Old 12-11-2012, 08:40 PM
rchase559
Are you trying to drive on pavement in 4wd?
rchase559 is offline
post #8 of 15 Old 12-12-2012, 07:34 AM
Pillswoj
Yes they will make the steering jerk at slow speeds.
OP it sounds like axle u joints to me, that is what mine felt like when they went.
Friends don't let Friends run Bosch
Pillswoj is offline
post #9 of 15 Old 12-12-2012, 09:01 AM
deadbiker
u-joints x3
deadbiker is offline
post #10 of 15 Old 12-12-2012, 09:34 AM
Greenfun2
Sounds like a U-joint, and is easy to check. Mine never made a sound when it went bad, but I got the slow speed jerk in the wheel, and all the needle rollers were rusted away in one of the caps.
Greenfun2 is offline
post #11 of 15 Old 12-12-2012, 04:22 PM
tjstevo
yes... but makes a ticking noise off road also and gets louder with acceleration
tjstevo is offline
post #12 of 15 Old 12-12-2012, 04:23 PM
tjstevo
wouldnt the front ujoints tick whike in 2wd also
tjstevo is offline
post #13 of 15 Old 12-13-2012, 12:52 AM
oakmckinley
When my power steering was going out the wheel didn't jerk, it just felt harder and harder to turn it. Had to put 2 hands on the wheel to turn it.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #14 of 15 Old 12-13-2012, 11:10 AM
dcope17
Front axle U-joints X7 or X8 where ever I am in the order...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #15 of 15 Old 12-13-2012, 11:53 AM
IslandTJ
Originally Posted by deadbiker View Post
u-joints x3
Now Jeeping in Oregon
IslandTJ is offline
Steering wheel jerks on turns in 2wd...bad U joint?? EABiker YJ Wrangler Technical Forum 14 10-03-2014 08:42 AM
Steering Wheel Jerks. . .Bad Track Bar? axs460 TJ Wrangler Technical Forum 4 07-18-2012 01:11 PM
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
shaky steering wheel at low speeds mlombardi TJ Wrangler Technical Forum 4 07-18-2009 04:54 AM
TJ jerks to right at highway speeds Superhoob TJ Wrangler Technical Forum 3 04-19-2009 04:51 PM
