steering linkage bracket - JeepForum.com
post #1 of 15 Old 03-22-2007, 05:25 PM Thread Starter
Rubikahn
Rubikahn's Avatar
steering guide bracket
So...I just installed a 1" steering guide spacer under the steering shaft bracket. Final piece to my 1" bl. Anyone know what torque specs are for the two bolts and two nuts for bracket? Did search... only got six hits none that matched what I am looking for.
Rubikahn is offline
post #2 of 15 Old 03-22-2007, 05:28 PM
1BadTJ
1BadTJ's Avatar
steering linkage spacer, wut the hail is a steering linkage spacer?
1BadTJ is offline
post #3 of 15 Old 03-22-2007, 05:38 PM Thread Starter
Rubikahn
Rubikahn's Avatar
Sorry my bad... it is a steering guide bracket. The 1" spacer lifts up the bracket to keep the angle of the steering shaft the same after a 1" bl.
Rubikahn is offline
post #4 of 15 Old 03-23-2007, 04:02 PM
Greg_Volkman
huh?????????
Greg_Volkman is offline
post #5 of 15 Old 03-23-2007, 04:11 PM
1BadTJ
1BadTJ's Avatar
you musta got some fancy body lift, cuz mine came with some pucks and bolts.
1BadTJ is offline
post #6 of 15 Old 03-23-2007, 04:22 PM
rob5059MOD
rob5059MOD's Avatar
Just tighten them up. I can not find anything in the FSM.
07 JK Rubicon
SOLD 06 Wrangler Unlimited Khaki, Congo Cage, D30 w/Aussie & D44 w/ Limited slip and 3.73 gears, 231HD transfer case with 2LOW and JB Conversions SYE with a Tom Woods DS. LIFT: Full Traction 4" Ultimate lift and JKS BL, Brown Dog MML. SKIDS: Jeep Medic TT and Oil Pan, Warn Gas Tank, and Rusty's Steering Box & Radiator. STEERING: ZJ steering, and PCS Steering Box. Running on 35" BF Goodrich Mud Terrains. And to ruin the look, I added Warn 6" flares to keep it legal.
rob5059MOD is offline
post #7 of 15 Old 03-23-2007, 05:50 PM Thread Starter
Rubikahn
Rubikahn's Avatar
Thanx Rob I bought the FSM on cd and I couldn't find it either. So I just tightened them... then two more turns. I bought a m.o.r.e. 1" body kit. It came with pucks, new rubber mounts, the steering spacer and a transfer case bracket. .
Rubikahn is offline
post #8 of 15 Old 03-23-2007, 08:50 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Greg_Volkman
huh?????????
In the middle of the intermediate steering shaft there is a support bearing that bolts to a frame mount. If you do a body lift without addressing it, you wind up with a very steep angle on the lower steering joint.
We just cut the bracket right below where the bearing mounts and weld in a piece of 1" strap to make it longer or taller depending on how you look at it.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #9 of 15 Old 03-24-2007, 04:21 PM
55willystruck
What type of issues would you have if you didn't address it? Is the steeper angle going to bind or hang up somehow?
Thanks,
Best of Luck,
Mike
55willystruck is offline
post #10 of 15 Old 03-25-2007, 07:52 AM
rob5059MOD
rob5059MOD's Avatar
From what I have read, and may be BS. It will wear out the U-joint on the intermediate shaft quicker.
07 JK Rubicon
post #11 of 15 Old 03-25-2007, 09:19 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Personally, I don't think it makes a difference. I just do it because I can and it offends my mechanical sensibilities not to.
I am Savvy
mrblaine is offline
post #12 of 15 Old 03-25-2007, 12:23 PM
55willystruck
Thanks Blaine-I was concerned maybe I should do something to "fix" it as I've run for over a year now with the JKS 1.25" BL, and no steering correction. Wasn't aware of what I needed to fix, as it hasn't appeared to be broken at this point. Sounds easy enough to modify though-just a piece of 1" flat stock, cut and welded in place to raise the section a bit, ease the angle. No biggie, maybe I'll look into doing something just for kicks. Can't hurt.
Thanks again,
Best of Luck,
Mike
post #13 of 15 Old 03-25-2007, 12:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Thanks again,
Best of Luck,
Mike
We have several rigs that play in the rocks and have done so for years with no ill effects. While I can safely predict no ill effects, I can't do it with 100 percent certainty.
I am Savvy
mrblaine is offline
post #14 of 15 Old 03-28-2007, 11:10 AM
2004JeepTJ
2004JeepTJ's Avatar
I have been running my JKS 1.25" BL for over 2 years and about 15k miles. Recently I have been getting a loud "clunk" in my steering. I believe it is coming from one of the u-joints in the steering shaft. I did NOT install any steering shaft spacers or brackets when I did my BL, so I am thinking that my steering shaft is binding in certain spots. When I am stopped and I turn my steering wheel CCW, I can make the "clunk" noise over and over. At first I thought my steering box was unhappy, but now based on this duscussion i wonder if my steering shaft u-joint(s) are binding?
Does anyone have pictures of their spacer installation? That would be helpful.
Thank you.
Hoping to get back into the Jeep world soon.
2004JeepTJ is offline
post #15 of 15 Old 04-25-2012, 11:17 PM
freetuck
its your steering shaft bearing and i cant find one anywhere and no one nows where
freetuck is offline
TC Shifter Bracket / linkage paine TJ Wrangler Technical Forum 22 03-23-2009 05:49 PM
AA linkage bracket/ linkage adjustment? Wrangler11 TJ Wrangler Technical Forum 1 06-01-2007 07:56 PM
wiper linkage bracket Wheelz TJ Wrangler Technical Forum 3 12-11-2006 06:03 AM
AA linkage bracket install garrynakamura TJ Wrangler Technical Forum 6 12-02-2005 06:45 PM
Trans linkage bracket. glennv TJ Wrangler Technical Forum 3 01-23-2003 09:38 AM
