steering leak ?? - JeepForum.com
post #1 of 7 Old 07-06-2010, 04:55 PM Thread Starter
jshaab2
steering leak ??
hey yall so i picked up at TJ for dirt cheap shes running fine everything basically good has small break leak and steering and idk but when i shift into upper gears 1-3-5 the shifter hits the dash . shes lifted with 2inch suspension and 2inch body and looks like it has unnecessary tcase drop ... well anyways first things first leakin looks like its dripping down pitman arm . how would i begin to fix this .
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline
post #2 of 7 Old 07-06-2010, 04:58 PM
BriansCJ
1994 XJ Cherokee
First take off the t-case drop and that combined with a BL will make the shifter travel differently in relation to the body causing it to hit the dash.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #3 of 7 Old 07-07-2010, 09:15 PM Thread Starter
jshaab2
thanks that i had figured out ..... anything on the steering ?
jshaab2 is offline
post #4 of 7 Old 07-07-2010, 09:18 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
is it leaking from the box itself, or one of the lines from on top?
Mail crawling.
MisfitSeven is offline
post #5 of 7 Old 07-08-2010, 09:34 PM Thread Starter
jshaab2
yeah i think if i heard correctly if its leaking from bottom its seals and if its up top i need a new box? and after i had 3 ppl look at it they all said its from the top - where can u pick up a new/ used or stronger steering gear box ?
jshaab2 is offline
post #6 of 7 Old 07-09-2010, 11:46 PM
TJ_Maniac
I have the same problem. Practically stole this 97 TJ from a guy who had lost his job and was selling off everything. Unfortunately, I have the same leaky steering gear. I've heard that you can use a 98/99 Durango steering box. It's supposed to be a more heavy duty box than the Jeep one and it bolts right on. I was also going to look into a seal kit to see if it wasn't too difficult to do. Anyone here know if its that difficult? Mine is leaking from the sector gear (pitman).
TJ_Maniac is offline
post #7 of 7 Old 07-10-2010, 11:47 PM Thread Starter
jshaab2
pitman leak is gotta be the seals but im gonna need a new steering box .
jshaab2 is offline
steering , box , leak , TJ
Power steering leak / Steering knocking. AustinCJer TJ Wrangler Technical Forum 13 01-12-2010 05:59 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
Steering Box Leak Sahara97TJ TJ Wrangler Technical Forum 1 03-26-2009 08:20 PM
Steering box leak dale88 TJ Wrangler Technical Forum 5 01-23-2009 09:23 PM
steering box leak jeepin1995 YJ Wrangler Technical Forum 1 04-01-2005 01:57 PM
