Steering Knuckle is stripped @ lower caliber bolt attachment hole - JeepForum.com
post #1 of 5 Old 08-05-2007, 08:53 AM Thread Starter
Jeepin088
Was replacing the wheel bearings and took the brake pads off. After installing the new wheel bearings when I went to put the brake caliper bolts back on, the lower bolt won't stay in the steering knuckle hole. The bolt itself is fine, but the part that it attaches to seems to be stripped. Please help! I'd rather not have to replace the entire steering knuckle!
Thanks!
Jeepin088 is offline
post #2 of 5 Old 08-05-2007, 09:07 AM
otisdog
2008 WK
otisdog is offline
post #3 of 5 Old 08-05-2007, 02:29 PM
Dogman
Dogman's Avatar
PM mrblaine, he sells a kit to fix this.
John 3:17
Dogman is offline
post #4 of 5 Old 08-05-2007, 02:33 PM
silvergoat
If the treads are stripped you may have to drill it out and install a threaded insert. Their are several kinds to choose from.
silvergoat is offline
post #5 of 5 Old 08-05-2007, 07:16 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can use a heli coil to fix this. Lock-tite it in and it will be fine.
Remember to only torque caliper bolts to 10-15 ft lbs.
Wheelin98TJ is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 06:59 PM
Help please…stripped belly pan bolt hole in frame vetdezracer TJ Wrangler Technical Forum 5 12-11-2009 07:18 AM
Tailgate bolt hole stripped, help Redleg13 TJ Wrangler Technical Forum 2 07-14-2009 02:39 PM
dana 30 steering knuckle stripped now what rip_1986 YJ Wrangler Technical Forum 11 04-21-2009 03:03 PM
Size of helicoil for caliper bolt/stripped knuckle repair? Alheim YJ Wrangler Technical Forum 8 05-23-2007 05:46 AM
