Steering Knuckle - JeepForum.com
post #1 of 6 Old 01-07-2008, 11:22 AM Thread Starter
TimBrown
Steering Knuckle
Will the passenger side steering knuckle from an 06' work on a 04 axle, Dana 30 of course?
TimBrown is offline
post #2 of 6 Old 01-07-2008, 11:31 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The steering knuckles all the way back to mid run on the YJ's, XJ's, ZJ's, MJ's, and all TJ's including the Rubi's and Unlimiteds all share the same knuckle provided it's the one piece style like the TJ uses.
Earlier knuckles had a separate caliper mount that bolted to the knuckle.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 6 Old 01-07-2008, 02:56 PM Thread Starter
TimBrown
Does anyone else have some input on this topic?
Its not that I don't trust you mrblaine just want to be sure before I start tearing things down.
TimBrown is offline
post #4 of 6 Old 01-07-2008, 03:03 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you need more input, then it's very clear you don't trust me. I doubt you'll find a single individual on Jeep Forum or any other TJ board that has cut up, modified, handled or knows more about the TJ knuckle and what it will and won't fit than I do.
I've literally been in charge of selecting over a thousand of them for Van's brake kits and the repairs I do at home.
Take it as you will, I am 100 percent correct without even a remote possibility for rebuttal.
In fact, you can go to your local parts store and look up the brake caliper for the TJ, then start crossing the caliper # over to various years and models in the Jeep line to verify that I am indeed correct.
I am Savvy
mrblaine is offline
post #5 of 6 Old 01-07-2008, 04:57 PM
19OlllllllO41
19OlllllllO41's Avatar
Yes, I agree with MrB, it will work.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #6 of 6 Old 01-07-2008, 05:04 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You will find no one better qualified to answer your question than mrblaine... to say the least. Blaine designed a stronger replacement version of that knuckle for a better brake system he also designed (or at least co-designed) being sold commercially.
Gone on vacation until August 25.
Jerry Bransford is offline
Steering knuckle Apex TJ Wrangler Technical Forum 3 09-16-2009 12:01 PM
over knuckle steering flys_yj YJ Wrangler Technical Forum 0 09-27-2008 01:22 PM
Steering Knuckle nat441 TJ Wrangler Technical Forum 2 05-18-2007 12:17 PM
Why did jeep use the Y steering linkage instead of tie rod go from knuckle to knuckle jzmtl TJ Wrangler Technical Forum 0 04-30-2007 08:56 AM
Steering Knuckle sfr246 TJ Wrangler Technical Forum 2 09-03-2004 01:38 PM
