Steering issue when turning left - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Steering issue when turning left
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 07-13-2011, 05:12 PM   #16
jjenkins11
So I replaced both front u-joints, but I still have the same issue.
Could it be in that shock (?) that attaches to the drag link?
"you don't drive a jeep.......you ride one"
http://www.frozentimephotography.net
jjenkins11 is offline   Reply With Quote
Unread 07-13-2011, 05:33 PM   #17
26679cj5
i'm having a similar issue where i'm getting a huge popping sound and a jump in the steering wheel when i turn sharp all the way in either direction. I just installed a spartan locker a couple weeks ago and its only been doing it since then, so that should be the obvious issue but the install went smoothly and everything seemed to check out fine. Did you happen to install a front locker recently also?
26679cj5 is offline   Reply With Quote
Unread 07-13-2011, 05:48 PM   #18
jjenkins11
No, no front locker install, but I did have that same issue. The new wheel bearing/hub solved that.
Unread 07-15-2011, 07:55 AM   #19
jjenkins11
I noticed when I had it in the air and turned the wheel I didn't feel the problem. I do when it is under power (and on the ground).
Could a slipping belt do this?
Unread 07-26-2011, 10:26 AM   #20
jjenkins11
Anyone have any thoughts on where to look next?
