#1 | |
Steering Gearbox Replacement
Last night I replaced the steering gear box on my 2001 TJ Sport. I got everything together fine except for the steering column shaft. Since I live in the midwest, I'm guessing road salt ate up the column/box. I was able to get the old gear box out with a little pursuasion, but getting the new one in was a problem. I wasnt able to get the steering column all the way down on the new gear box spline. Its probably 3/4 of the way on right now and seems to be fine, but I dont want it to slip off or break. Any suggestions on how to get it on further?? Thanks!
#2 | |
If you did get that bolt in and tightened you are fine. If not, don't drive it until you've fixed it. |
#3 |
I did get the bolt in, but it still seems about 3/4 of an inch higher than it was when I pulled it off.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
