Steering feels soft after lift kit install - Page 3 - JeepForum.com
post #31 of 37 Old 03-22-2012, 01:08 PM
scot68
Originally Posted by Heath View Post
Way too high pressure. Also you should be at zero-just in on the toe.
No, toe should be set at about 1/16 "in" with a 31" tire.
scot68 is offline
post #32 of 37 Old 03-22-2012, 01:10 PM
Sundowner
Originally Posted by Cuder View Post
I have always herd that the tow-in should be at 1/16"-1/8".
The toe is subjective, like almost everything else on any given Jeep. 1/8" is a starting point, and it's worth mentioning that the 1/8" is measured under the assumption of a 35" tire. Some people run 5/32", some 1/32". It's trial and error, sometimes. Different tire/wheel combinations perform in different ways on different Jeeps.
Sundowner is offline
post #33 of 37 Old 03-22-2012, 01:44 PM
Heath
2014 JK Wrangler
Have you also HEARD that about the TOE?
2013 JKU Rubicon
Heath is offline
post #34 of 37 Old 03-22-2012, 02:04 PM
Heath
2014 JK Wrangler
That's right. Usually zero to a hair in. 1/16" is a hair IMO. I have got to where I set my toe 1/16th out then drive then adjust it in 1/8 turn on the collar then drive again, and repeat till I get the road feel I like. I have found it to be 1/16th-1/8th in between 31-37" tires.
2013 JKU Rubicon
Heath is offline
post #35 of 37 Old 03-22-2012, 03:18 PM
Keith_C
Originally Posted by wallwm View Post
Gentleman please this is not a contentious issue. I asked about these cam alignment bolts when I purchased the kit and was told they SHOULD not be necessary but it sounds like they could be the trick.
My first lift was a 2" BB.
It felt like it was all over the road, slow return to center.
I installed the cam bolts and it was perfect.
My Jeep's never been on an alignment rack.
I just used eyeball and angle gauge to set the caster.
Maybe I just got lucky.
Keith_C is offline
post #36 of 37 Old 03-22-2012, 05:29 PM
Gary2
I don't bother with Jack stands and removing the tire/wheels for toe and this way I know I am at ride height . Your caster should not be that far off with just a few inches of lift to cause the issue you seem to have . Most shops insist on setting caster at OE specs which is more than most of us require being you need less as you go up in tire size to a certain point . toe 1/16 to 1/8 is fine . Both caster and Toe can be set at home . get used to doing it owning a Jeep you are always changing things that effect at least toe. here is a pic of how I do it . you can pick up all you need at Home depot including an angle finder to set caster . you can refine your tools as you learn .
Gary2 is offline
post #37 of 37 Old 03-22-2012, 07:36 PM
flying_bosun
Originally Posted by Gary2
I don't bother with Jack stands and removing the tire/wheels for toe and this way I know I am at ride height.
That's the ticket!. Thanks for the pic.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
cross , lift kits , steering
Steering feels almost like im in 4wd...? mystangt TJ Wrangler Technical Forum 2 06-02-2011 08:17 PM
Feels something loose in steering marzak4d JK Wrangler Technical Forum 4 07-18-2009 11:55 PM
Steering feels sloppy after a new lift?? HitIt TJ Wrangler Technical Forum 12 05-21-2007 02:55 PM
Steering feels light!!! blacktj TJ Wrangler Technical Forum 5 01-15-2006 11:34 PM
Steering Feels weird.. The Fuzz YJ Wrangler Technical Forum 4 07-18-2004 11:45 AM
