Steering feels soft after lift kit install - JeepForum.com
post #1 of 37 Old 03-21-2012, 06:26 PM Thread Starter
wallwm
I just installed a Cross 3.5" lift kit and Goodyear Duratrac 31x10.5-15 with new 15x8 rims on my 2000 TJ. The install went GREAT! No problems with the kit or the support.
I now seem to have very soft and super sentitive steering. It is like I have super power steering. My wife will not drive it because she connot control it when on the highway. You have to be very in control when changing lanes or you could lose it. I rechecked all bolt tightness and also checked for anything lose or with alot of play. I found nothing obvious. Is this to be expected with a lift kit? What can I check.
The Cross kit came with everything, gas shocks, springs, offsets for front & rear. Everything was installed from the kit and had it realigned by a PRO.
Thanks for any feedback.
wallwm is offline
post #2 of 37 Old 03-21-2012, 06:44 PM
grnsporty
Did you put a drop pitman arm on? if so take it off. I believe your complaining about bumpsteer.
grnsporty is offline
post #3 of 37 Old 03-21-2012, 06:49 PM
biffgnar
biffgnar's Avatar
Bumpsteer? No. Did you get an alignment after lift?
Romney in 2020!
biffgnar is offline
post #4 of 37 Old 03-21-2012, 06:56 PM
grnsporty
He said he had it aligned after the lift. How is it not bumpsteer? I used to have it when I had a drop pitman arm and it was sensitive.
post #5 of 37 Old 03-21-2012, 07:04 PM
flying_bosun
My first thought was the the OP offered a really , um, "unusual"?, description for bumpsteer, too.
Pics of the steering taken from in front at diff level so that the front pumpkin blocks the view of the rear will help us help you, wallwm.
Edit: WTF is a "Cross 3.5" lift" and where did you get it? Granted, I didn't look too hard, but I couldn't find anything under "Cross" for suspension or lifts via Google. A link and parts list and pics will help
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #6 of 37 Old 03-21-2012, 07:04 PM
Keith_C
Caster.
Keith_C is offline
post #7 of 37 Old 03-21-2012, 07:19 PM
scot68
Originally Posted by Keith_C View Post
Caster.
X2... To much Caster... Also the Alignment Tech properly set the Tow to factory specs which isn't the best larger tires. Did this lift come with adjustable control arms?
scot68 is offline
post #8 of 37 Old 03-21-2012, 07:46 PM Thread Starter
wallwm
Thanks for the feedback. I had an OF moment. The kit was a Zone ZONJ2N. No it does not have a dropped Pitman Arm as asked above. I have not heard of bumpsteer. Interesting term, I will look into it. A local profession shop who does Jeep alignments said only toe in was off as expected all else was well within factory Jeep specs. Pending other comments I will post some pictures.
The Zone kit is at http://zoneoffroad.com/product?ki=21&gr=-1
Thanks for the feedback and pardone my OF moment.
wallwm is offline
post #9 of 37 Old 03-21-2012, 07:58 PM
Cuder
What tire pressures are you running? Do you have a steering stabilizer?
My Build Thread:
Cuder is offline
post #10 of 37 Old 03-21-2012, 08:09 PM Thread Starter
wallwm
I am running 32 PSI in the tires and yes I have a steering stabilizer with about 15K miles on it. The SS is something I was going to check tomorrow and see if it is part of the problem. I was also going to lower the pressure in two PSI increments and see if anything changes.
Thanks
wallwm is offline
post #11 of 37 Old 03-21-2012, 08:09 PM
Sundowner
Sounds to me like improper toe adjustment, which can make it wander a lot...and also a caster issue, perhaps. It's not bumpsteer.
Sundowner is offline
post #12 of 37 Old 03-21-2012, 08:16 PM
dla
Caster.
X3...
Actually, not enough caster. Caster angle decreases as the Jeep is raised.
Too little caster results in light steering, wandering and problems with steering returning to center after a turn. Can be adjusted +/- 1.5° by adding alignment cam bolts on the front lower control arms, more with adjustable arms.
As stated on the Zone link you provided... "J5311 - Alignment cams are recommended if your vehicle didn't come from the factory with front cam bolts."
dla is offline
post #13 of 37 Old 03-21-2012, 08:19 PM
RaggedOleMan
No he didn't. Yours was the 4th post and he said/posted nothing about having it aligned prior.
I agree, and would start there. There's a variety of ways a guy can check the toe. There's a good write-up on Setting the toe on Stu Olson's site.
RaggedOleMan is offline
post #14 of 37 Old 03-21-2012, 08:23 PM
grnsporty
Umm yea it did but whatever dude no need to start a pissing match.
post #15 of 37 Old 03-21-2012, 08:24 PM
flying_bosun
Mine was the fifth post and the op clearly stated that the alignment was done by a "PRO" in post #1.
I'm leaning toward a caster issue, too, fwiw.
― Ron Paul
cross , lift kits , steering
Steering feels almost like im in 4wd...? mystangt TJ Wrangler Technical Forum 2 06-02-2011 08:17 PM
Feels something loose in steering marzak4d JK Wrangler Technical Forum 4 07-18-2009 11:55 PM
Steering feels sloppy after a new lift?? HitIt TJ Wrangler Technical Forum 12 05-21-2007 02:55 PM
Steering feels light!!! blacktj TJ Wrangler Technical Forum 5 01-15-2006 11:34 PM
Steering Feels weird.. The Fuzz YJ Wrangler Technical Forum 4 07-18-2004 11:45 AM
