Steering box adjustment - JeepForum.com
post #1 of 6 Old 07-07-2010, 04:41 PM Thread Starter
matthewh_1
Don't ask how, but the adjuster nut on top of my steering box got way outta whack. How do I get it in the right position?
National Topless Day 2010 winner!
Zombie Outbreak Response Unit #70
Originally Posted by jclauson View Post
When a girl tells you your flex is sexy then you are doing something right in life.
matthewh_1 is offline
post #2 of 6 Old 07-07-2010, 05:11 PM
durango-bob
2006 WK
Tighten it down until it you feel it bottom out then back it off about a half turn. That will be close and if it seems too loose when you drive it, you can tighten it a bit more.
durango-bob is offline
post #3 of 6 Old 07-08-2010, 02:21 PM
BlueFlame
BlueFlame's Avatar
Do not be tempted to tighten it too much. Err on the side of 'not tighter.'
How did it get out of whack? someone accidentally mess with it?
BlueFlame is offline
post #4 of 6 Old 07-08-2010, 02:32 PM
bruteboy
the steering box needs to be centered BEFORE any adjustment is made.
adjusting a steering box that is not centered will cause problems.
bruteboy is offline
post #5 of 6 Old 07-08-2010, 03:50 PM
BlueFlame
BlueFlame's Avatar
Here's the correct procedure:
post #6 of 6 Old 07-08-2010, 04:32 PM
Apex
Recon death squad
Apex's Avatar
hmm...seems like a lot of work.
Apex is offline
steering , box , adjustment
Steering box adjustment??? TJ-xtreme TJ Wrangler Technical Forum 10 08-25-2009 01:33 PM
Steering adjustment BobA TJ Wrangler Technical Forum 9 05-14-2009 02:48 PM
Steering box adjustment? aryana TJ Wrangler Technical Forum 13 10-04-2006 04:57 PM
steering adjustment? leaptj YJ Wrangler Technical Forum 6 04-10-2006 06:02 PM
AGR Steering Box adjustment Broadway TJ Wrangler Technical Forum 0 10-05-2003 06:20 PM
