Steering - JeepForum.com
post #1 of 27 Old 11-10-2012, 11:46 AM Thread Starter
johnjr602
Steering
Anything wrong here
Isn't fun the best thing to have?
johnjr602 is offline
post #2 of 27 Old 11-10-2012, 11:49 AM
FAW-CAN-ADIAN
looks like its time for an upgrade!
FAW-CAN-ADIAN is offline
post #3 of 27 Old 11-10-2012, 12:20 PM
JeSimmers
JeSimmers's Avatar
Drop pitman arm with stock frame mount for trackbar.
Red Jeep Club Member #454
JeSimmers is offline
post #4 of 27 Old 11-10-2012, 12:38 PM
FAW-CAN-ADIAN
i was thinking bent tie rod.
post #5 of 27 Old 11-10-2012, 12:49 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just to clarify, I am 100% certain JeSimmers makes that recommendation in jest.
Jerry Bransford is online now
post #6 of 27 Old 11-10-2012, 02:23 PM Thread Starter
johnjr602
Ah this is exactly the feed back I need. So I should get a track bar bracket for the frame side or the axle side? And remove the dpa?
post #7 of 27 Old 11-10-2012, 02:26 PM Thread Starter
johnjr602
And I'm not sure, but I don't think the tie rod is bent. It's fairly new and I don't go off road. But hey it very well could be
post #8 of 27 Old 11-10-2012, 02:26 PM
Jerry Bransford
Administrator
Hard to say what is serious and what was said in jest in this thread... assuming nothing, I'll just cut to the chance and say your tie rod is severely bent, replace it. If you have a dropped Pitman arm, definitely get rid of it... replace it with the factory OE Pitman arm. No, don't install a dropped track bar mounting bracket.
post #9 of 27 Old 11-10-2012, 02:31 PM Thread Starter
johnjr602
Now if I get rid of the dpa will the drag link and drag bar be a more of a different angle than they are now? I mean as it sits they seem pretty close
post #10 of 27 Old 11-10-2012, 02:32 PM Thread Starter
johnjr602
Is what I meant
post #11 of 27 Old 11-10-2012, 02:33 PM Thread Starter
johnjr602
Track bar and drag link is what I meant
post #12 of 27 Old 11-10-2012, 02:34 PM
biffgnar
biffgnar's Avatar
No. They cross now. Raising pitman arm end of draglink will change that.
biffgnar is offline
post #13 of 27 Old 11-10-2012, 02:40 PM Thread Starter
johnjr602
Got ya. I think I understand.
post #14 of 27 Old 11-10-2012, 02:43 PM
FAW-CAN-ADIAN
from the angle of the picture,your drag link(tie rod that conects to pitman arm)looks like its running at the same angle as the track bar(which it should).the tie rod(that connects the draglink to the drivers side steering arm looks bent which would cause your wheels to be toed in.
post #15 of 27 Old 11-10-2012, 02:48 PM Thread Starter
johnjr602
See that's why I'm confused. To me it looks like they are at the same angle. But I can see how they cross too
