Staun or Trailhead Tire Deflators - JeepForum.com
post #1 of 21 Old 06-04-2007, 09:08 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Anyone used Staun? Are they any better than the Trailhead?
http://cgi.ebay.com/ebaymotors/STAUN...QQcmdZViewItem
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #2 of 21 Old 06-04-2007, 09:16 PM
luk4mud
Never heard of trailhead, but my Stauns sure work well.
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline
post #3 of 21 Old 06-04-2007, 09:20 PM
IGotADisneyJeep
IGotADisneyJeep's Avatar
I have Stauns they do very well airing down. At times its sucks adjusting it for the right pressure.
But, all in all I'll give it a 4 star out of 5.
At $45.00 is a good price
I'm Michael, Founder of: "Jeeps Gone Wild™"
www.JeepsGoneWild.org
IGotADisneyJeep is offline
post #4 of 21 Old 06-04-2007, 09:22 PM Thread Starter
Thunderstrike
2009 JK Wrangler
OK, good deal -- Stauns it is.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #5 of 21 Old 06-04-2007, 09:23 PM
TJ on the Rocks
TJ on the Rocks's Avatar
HERE's a great comparison write-up of several deflators .
I use the TrailHead deflators , they could be a bit more precise for my tastes .
I have a wheeling friend that uses the Stauns . I kinda like them better .
TJ on the Rocks is offline
post #6 of 21 Old 06-04-2007, 09:41 PM
Gerg
Gerg's Avatar
Hint on setting the presure on the Stauns. Get your wheelbarrow (or borrow one) to set the pressure. Real quick to reset/reinflate and air down.
Greg
Bakersfield, Ca.
Red Jeep Club #321
Gerg is offline
post #7 of 21 Old 06-04-2007, 10:26 PM
luk4mud
How would that work? Air pressure in a wheelbarrow tire, given a smaller circumference, wouldn't seem like it would transfer to Jeep tires. If I want 14lbs in my 33" BFG's, wouldn't setting all 4 Stauns at 14lbs on the same Jeep tire (using a pressure gauge to check) work fine and actually be more accurate?
luk4mud is offline
post #8 of 21 Old 06-04-2007, 10:34 PM
TJ on the Rocks
It works .
I did the same with my TrailHeads .
Setting and deflating to any pressure setting on the Jeep tires takes forever .
It's real quick when using a wheelbarrow tire to set them up .
14 psi , no matter which tire is the same .
Less volume in the wheelbarrow tire = much faster set-up time .
See the paragraph just under the picture of all
the different deflators being tested on the link I posted .
post #9 of 21 Old 06-05-2007, 08:32 AM
luk4mud
Originally Posted by TJ on the Rocks
It works .
Hey, thank for the info. That's a great link, too.
luk4mud is offline
post #10 of 21 Old 06-05-2007, 11:01 AM
AZG23
I just used my spare......aired down to what I wanted (10 lbs)...set..rechecked..added a few more lbs of air and verified they were at 10lbs..reair to 15 lbs (quick) and repeat on the rest
Brad B.
"If you cant understand that, your face needs to be set ablaze with kerosene and promptly put out with a wet brick."
AZG23 is offline
post #11 of 21 Old 06-05-2007, 11:21 AM
NavinRJohnson
You might consider the Currie EZ deflator. I air down quicker than the Staun fellas and it is more consistent. Really easy.
The D35: 60% of the time, it breaks every time.
'06 LJ (specs in profile, 35's, ARBs, rocket boosters, stealth technology, etc.)
NavinRJohnson is offline
post #12 of 21 Old 06-05-2007, 11:27 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, I finally got a Currie EZ Deflator and it's pretty darned nice. Very fast deflation times too since it removes the center valve core while you're airing down.
Jerry Bransford is online now
post #13 of 21 Old 06-05-2007, 11:43 AM
RUB1CON
RUB1CON's Avatar
And for the price of a set of stauns you can buy two Currie's and have a buddy do one side while you do the other side
'03 Rubicon
RUB1CON is offline
post #14 of 21 Old 06-05-2007, 12:38 PM
AZG23
I consistantly finish before my buddy with the Currie...and he only goes down to 15 on 33's...I do 10lbs on 35's....AND Im not bending down at every tire for the duration of the airdown...screw em on and walk away...come back after BS'n and take em off...
Brad B.
AZG23 is offline
post #15 of 21 Old 06-05-2007, 12:40 PM
TJ on the Rocks
Using Staun's ?
Staun+DynaBeads+flat tire=instant death wobble? NotURMailman TJ Wrangler Technical Forum 30 12-01-2010 01:57 PM
anyone ever use these tire deflators? freeunit TJ Wrangler Technical Forum 83 09-29-2009 11:57 AM
Smittybuilt Deflators Woodchuck JK Wrangler Technical Forum 21 08-14-2008 11:03 AM
Staun Beadlocks Brent_f70 JK Wrangler Technical Forum 7 03-05-2008 08:29 AM
My Trailhead compressor arrived,instal question?? RCJS YJ Wrangler Technical Forum 0 06-06-2002 10:04 PM
