Startup Issue?? - JeepForum.com
post #1 of 6 Old 07-03-2013, 09:22 AM Thread Starter
robertsk1
Startup Issue??
Hey guys, new member on the forum here after many months of crawling all over it. So I'm having a bit of an electrical gremlin. I have a leaky gas regulator on the fuel pump, so whenever I start the jeep cold, I turn the key to ON, then OFF, about 3-4 times to get gas back in the system. The jeep usually turns over without issue. Well about 3-4 days ago, the jeep refused to crank, (in the parking lot 20 miles from home, figures). I narrowed it down to a corroded connection between the battery cable and the PDC fuse box under the hood. I cleaned that connection and it started right up.
Well this morning, I did the usual key on/off deal, my dash lit up like normal, the jeep beeped at me to tell me the keys where in the ignition, go to crank, something like a 'thunk" and then nothing. Tried to turn it again, nothing, and my dash lights were barely flickering. Put a volt meter to the battery, 12-14 volts (I have an old meter not very accurate). Volt meter to the PDC post, same reading. So I had my father turn the key while I listened under the hood and there's a buzzing coming from the fuse block under the hood.
Didn't have time to jump it or check which relay it was, I was late for work as is. My suspicion is that the battery can hold a charge, but can't take a load.
Any thoughts? I have a 97 wrangler, 4.0. I appreciate any insight you may have
Thanks in advance
robertsk1 is offline
post #2 of 6 Old 07-03-2013, 09:40 AM
JeffBowser
I'da taken a voltage reading while he turned the key. Battery is a good place to start, these things can't run without a good battery.
JeffBowser is offline
post #3 of 6 Old 07-03-2013, 09:43 AM Thread Starter
robertsk1
PO said battery can't be more than two years old. So it seems unlikey, but not impossible. However the dash lights being dim after trying to crank would be a symptom of the battery not being able to handle the load, correct?
post #4 of 6 Old 07-03-2013, 09:47 AM
JeffBowser
That's my line of thinking, along with that buzzing. The "thunk" is a wild card, I don't know what to make of that, but testing the battery is certainly the first place I'd go.
post #5 of 6 Old 07-03-2013, 12:13 PM
NotURMailman
I would guess weak battery.
The "thunk" was probably the bendix engaging the flywheel, just not enough juice for the starter to actually turn the engine over.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #6 of 6 Old 07-03-2013, 04:57 PM Thread Starter
robertsk1
In case anyone was wondering, I cleaned the connections on the battery terminals, the starer, and the engine ground and it fired right up. Hopefully that does it.
