starting trouble; now check engine light (need help) - JeepForum.com
post #1 of 2 Old 02-05-2009, 05:26 PM Thread Starter
dabrogger
the engine on my 97 tj with 95,000 miles on the 4.0 turned over today but didn't immediately start. i had to turn it over a couple of times then it started but died if i let off of the gas. then i turned it over for a bit again and it started but would die unless i kept the rpm's up; if i let them go down to normal idle, it would idle really rough then die. finally it started normal and i drove it around without any further problems. now the check engine light is on??? also, now it starts, idles, and runs like normal except for the check engine light. does anyone know what the problem is or might have been?
dabrogger is offline
post #2 of 2 Old 02-06-2009, 01:31 AM
Jonny Jeep
Jonny Jeep's Avatar
turn the ignition key on-off-on-off-on within five seconds. Leave it in the on position then watch the odometer display where the trouble codes will display. Go to this link to see what the codes mean...
http://www.allpar.com/fix/80s-codes.html
It sounds a bit like you might have battery problems. Could be a bad ground or bad connection at the battery too. See what the codes are then post back for more ideas from people.
Jonny Jeep is offline
Check Engine Light and O2 Sensor Trouble Dovemonkey TJ Wrangler Technical Forum 17 06-30-2017 09:39 AM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
Cold Starting Check Engine light woody59 YJ Wrangler Technical Forum 0 02-23-2008 07:37 PM
95 YJ 2.5L - Check Engine Light on when starting cold gary1 YJ Wrangler Technical Forum 7 02-03-2006 07:10 PM
Check Engine Light Trouble Jeep Named Thor YJ Wrangler Technical Forum 1 06-03-2002 02:26 PM
