Starting Problems.....Electrical? - JeepForum.com
post #1 of 19 Old 02-10-2011, 02:58 PM Thread Starter
bdrayer
2015 JK Wrangler
Hey guys,
I have a quick question. It could be a very easy answer or a complicated. This issue has happened twice with about a month in between the occurrences. Twice now my jeep, a 98 Wrangler with a 3.25 RC lift, a 2 in body lift, RC trackbar and a Warn Skid Plate, has not done anything when I have tried to start it. One occurrence just happened after I turned the engine off while pumping gas and then went to turn it back on and nothing happened. The other happened after I had left it overnight without driving for the night.
The issue that happens is that it seems as if the electrical system is dead, so I am thinking possibly battery.
Nothing lights up, nothing turns on. After trying to start it about 5-10 times it will finally begin to get stuff lighting up again and then it will finally start. The engine will crank and start but run a little rough until I give it some gas to keep it going for a few seconds.
The thing is that the month between these occurrences I have had no issues at all. It starts strong and I have no electrical issues.
My question is could this be as simple as a battery or could it be my starter or alternator?
Any info you guys could give me would be great.
Thanks,
Brett
bdrayer is offline
post #2 of 19 Old 02-10-2011, 03:04 PM
biffgnar
biffgnar's Avatar
Are your battery terminal connections clean and tight?
Romney in 2020!
biffgnar is online now
post #3 of 19 Old 02-10-2011, 03:14 PM Thread Starter
bdrayer
2015 JK Wrangler
I'd have to check again, but I haven't messed with them in about 3 months. When I did reconnect them, they were tight and pretty clean. Even if this was the case why would it finally begin to start after turning the key 5-10 times as I said.....
And I also forgot to say it is a manual, 6 Cyl.
bdrayer is offline
post #4 of 19 Old 02-10-2011, 07:13 PM
jeepnwayne
I've had the same problem. Turn key, nothing, nothing lights up or makes a sound, then on the 5th or 6th turn it will start but run rough or just die, then I'll turn the key it'll start but i have to put the gas on for a minute. That has been going on for a few months every once in a while. Recently my battery die (dome light on over night) jump started it a few days later the battery wouldn't hold a charge. Picked up a new battery yesterday, and now starts like a dream.
jeepnwayne is offline
post #5 of 19 Old 02-10-2011, 08:45 PM
wushaw
Rockin jeep
wushaw's Avatar
Clean the battery terminals with a battery post cleaner, make em shine...then see what happens.
Looking at them won't cut it when it comes to battery post connections.
wushaw is offline
post #6 of 19 Old 02-11-2011, 12:53 AM Thread Starter
bdrayer
2015 JK Wrangler
So the general consensus is that it is the battery?? Does any one think that it could possibly be a wire not properly grounded? This is a thought I got from some of my fraternity brothers.
Where are all of the grounds located?
bdrayer is offline
post #7 of 19 Old 02-11-2011, 09:51 AM Thread Starter
bdrayer
2015 JK Wrangler
bump
if anyone has anymore advice it would be greatly appreciated....I would love to get this figured out before I get stranded somewhere.....
bdrayer is offline
post #8 of 19 Old 02-15-2011, 10:55 AM Thread Starter
bdrayer
2015 JK Wrangler
bump......
anyone?
bdrayer is offline
post #9 of 19 Old 02-15-2011, 11:02 AM
Ahrnsbrak14
Yeah, first replace your terminals if they are old, make sure BOTH sides of the battery cables are connected. Not sure exactly the problem, dose the electrical come on but then you turn the key and nothing happens at all or dose nothing happen at all, no radio or lights or anything?
Ahrnsbrak14 is offline
post #10 of 19 Old 02-15-2011, 11:04 AM
Ahrnsbrak14
If it was your alternator your battery would be dead completely in about 3 days (brand new battery). Another thing you could do is go to a local auto parts store and have them check your battery, alternator and starter. Takes like 2 min
post #11 of 19 Old 02-15-2011, 11:08 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
X 2,Free is good.
TheBoogieman is offline
post #12 of 19 Old 02-16-2011, 12:57 PM Thread Starter
bdrayer
2015 JK Wrangler
Nothing happens at all. No lights no radio no anything.
And all of that sounds good guys I will clean up my battery and then get everything checked out. I'll let you know if anything happens.
bdrayer is offline
post #13 of 19 Old 02-16-2011, 01:40 PM
Ahrnsbrak14
Yeah then I would guess its something to do with your battery
post #14 of 19 Old 02-17-2011, 09:26 AM Thread Starter
bdrayer
2015 JK Wrangler
ok so the guy at autozone said that my battery, starter and alternator were all good. The only comment he made was that my alternator was pushing out 13.9 amps rather than 14.2 or so. Besides that all was good. So tomorrow when its supposed to be about 50 degrees here, I am going to go out and check out all my wires and grounds and make sure they are good....
any other ideas?
bdrayer is offline
post #15 of 19 Old 02-17-2011, 10:38 AM
Ahrnsbrak14
62 degrees here right now
Along with your wires make sure all the terminals are good and tight.
battery , electrical issue , starting
YJ Starting/Electrical Prob. No-Doors YJ Wrangler Technical Forum 12 07-27-2010 12:54 PM
starting/electrical issue??? need help twizz TJ Wrangler Technical Forum 1 05-24-2010 06:27 PM
YJ starting issue (perhaps electrical) Inch7706 YJ Wrangler Technical Forum 1 09-06-2008 05:33 PM
Odd electrical/starting problem tommygdbr TJ Wrangler Technical Forum 8 12-29-2006 01:33 PM
Need help with starting/electrical problem BaaBaa TJ Wrangler Technical Forum 4 05-06-2006 12:20 PM
