Starting issue question - JeepForum.com
post #1 of 13 Old 08-05-2010, 06:09 PM Thread Starter
WarrenW
I have a 97 TJ with the 4.0L. My wife has been driving it to work the last couple days and now died so I have to do by what she tried to describe. This morning she said it struggled to turn over but cranked. Then at work leaving it turned over slowly, then clicked some which I assume was the solenoid. She let off and then turned it over again and it started barely. She should have gone straight home but just like a woman, she decides to stop at Target to shop! Gets out to the jeep and then nothing - not even clicking. But everything else comes on like blower, etc.
I pick her up and go get a new battery. Put it in and there is not any clicking or turning over. But again, all of the accessories work. With the clicking and turning over slow I thought it would be the battery. Is that the starter that died? I don't think it would be the solenoid only because it turned over slow when it did.
What is your opinion? It's sitting at Target now and hope its fine tomorrow when I get there!!
Thanks,
Warren
WarrenW is offline
post #2 of 13 Old 08-05-2010, 08:36 PM Thread Starter
WarrenW
bump
WarrenW is offline
post #3 of 13 Old 08-05-2010, 09:14 PM
fishinjeeper
Starter solenoid
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #4 of 13 Old 08-05-2010, 09:33 PM Thread Starter
WarrenW
When you buy a new starter, does it come with the solenoid on it? I was just thinking of replacing the whole thing.
Why do you say it is the solenoid only? Thanks for the help!
WarrenW is offline
post #5 of 13 Old 08-05-2010, 10:54 PM
wushaw
Rockin jeep
wushaw's Avatar
Yes it comes with the solonoid.
wushaw is offline
post #6 of 13 Old 08-06-2010, 07:09 AM Thread Starter
WarrenW
I'm going to replace them both. But owuld the solenoid cause it to turn over slow if it was bad? The solenoid does not even click now.
WarrenW is offline
post #7 of 13 Old 08-06-2010, 07:47 AM
PeteYJTJ
you starter should look something like this. If you use a long screwdriver to jump the two big terminals on the back of the solenoid, you'll run the starter. If you do that, and the starter spins good and starts the motor, it's the solenoid. If you do that, and the starter still spins like crap, slow, or doesn't spin, it's the starter.
Good luck
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #8 of 13 Old 08-06-2010, 07:48 AM Thread Starter
WarrenW
Thanks, it does look like that. But just one quick question. If it does not click when I try to start it, wouldn't the solenoid be bad? If the starter was bad, the solenoid would at least click right?
WarrenW is offline
post #9 of 13 Old 08-06-2010, 08:06 AM
PeteYJTJ
Yeah, it should click. If it's not the battery, or your connections, which you should check closely, I'd replace the starter/solenoid pair. Usually they come together.
Could be ignition switch or wiring also. I'd isolate the whole circuit. If you jump battery positive to the small terminal on the starter solenoid, it should click and run the starter. That is the solenoid feed from the ignition switch. Also check that the starter has a good ground. Check your ground connetion at the block also for corrosion. Sometimes your connections are good enough to run things like the radio and lights, but not good enough for the 200-300 amps or whatever that the starter needs.
Good luck
Pete
PeteYJTJ is offline
post #10 of 13 Old 08-06-2010, 10:49 AM Thread Starter
WarrenW
On the positive terminal of the battery I have a smaller red wire that connects with it. I did not follow where that wire went but is that standard or added on? Is that the wire that goes to the ignition/solenoid?
I'm starting to think it is the solenoid because it was clicking/turning over at the end and now nothing. I would have bet it was the battery though.
I plan to try to push start it after work to get it home at least. With a 5-speed, is it best to put it in 3rd gear to push start or 2nd?
Thanks!
WarrenW is offline
post #11 of 13 Old 08-06-2010, 10:51 AM Thread Starter
WarrenW
The reason I'm asking on the red wire is because when I put a new battery in yesterday and it did not click or turn over, I pushed the cables on the battery tight but the red wire was very loose and not tightened. So if that was used for the starting, it didn't help being loose I'm sure.
WarrenW is offline
post #12 of 13 Old 08-06-2010, 03:59 PM Thread Starter
WarrenW
Okay, here is the latest! I push started it and just got it home. I turned it off and then turned the key to crank it. It turned over once, heard a click which was probably the solenoid and then died. All of the accessories come on still but will not turn over anymore. So what does this sound like?
Also, before I push started it I crossed the terminals on the back of the solenoid and it sparked some but nothing. No click or anything.
Thanks!!
WarrenW is offline
post #13 of 13 Old 08-06-2010, 05:50 PM
wushaw
Rockin jeep
wushaw's Avatar
Change the starter, your over thinking this, just change the starter....
wushaw is offline
starting , solenoid , starter , tj , wrangler
Starting issue knep25 TJ Wrangler Technical Forum 1 05-12-2010 01:06 PM
starting issue 97tjeff YJ Wrangler Technical Forum 1 07-31-2008 08:06 PM
Starting Issue jonnyri YJ Wrangler Technical Forum 2 02-15-2007 06:17 PM
YJ starting issue ezlovan YJ Wrangler Technical Forum 3 11-28-2006 03:00 PM
New issue with starting Coldfever YJ Wrangler Technical Forum 2 08-31-2005 07:43 AM
