Starter Solenoid or Starter Motor Problems - JeepForum.com
post #1 of 5 Old 10-20-2011, 10:00 PM Thread Starter
hjlueth0001
I own a 2006 Jeep Wrangler X with a 4L engine.
I woke up one morning unable to start the car. It's making an rapid clicking sound, but it's not trying to turn the engine over. After I had a friend give me a jump, I managed to start the engine. I filled her up with gas, and after that five minute period, the car started normally, but the starter motor was turning slowly, but managed to start the engine. However, when I tried to restart it after stopping in the store, the same problem appeared. The engine is clicking, but not attempting to turn over. I can't figure out whether it's the battery, the starter solenoid, or the starter motor. Any help would be greatly appreciated. Another notable symptom being that all the gauges are jumping while I'm turning the ignition. I opened up the hood and took a look in, and everything looked normally, the terminals on the battery are clean and there's no build-up there. The read-out on the voltage meter is above 9volts, so that's normal. However, there was a wire hanging near the belt that I hadn't seen before, but wasn't able to figure out where it came from as I had no light and this was after dark. Help, please.
hjlueth0001 is offline
post #2 of 5 Old 10-20-2011, 10:12 PM
DevilDogDoc
Get a new battery. 9 volts is not normal 13-14 is. And it's a Jeep not a car.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #3 of 5 Old 10-20-2011, 10:19 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
The solenoid clicking (chattering) repeatedly is a sure sign of low voltage. New battery time.
Rubi4MyMrs is offline
post #4 of 5 Old 10-20-2011, 10:34 PM
2004sahara
Yup...get a new battey, and clean and tighten your cables. Do this ASAP, or you will need an alternator too. (you may need one now?)
Clean connections on your starter.
If your starter is bad, you will need a core.........if your starter is only worth core charge and you have time..take it apart and see what makes it tick....if you mess up no big deal cause you are trading it in anyway.
all the best to you and your jeep
2004 sahara, 2 inch BDS spring lift, BDS discos, 31bfg at, on ravines.
2004sahara is offline
post #5 of 5 Old 10-20-2011, 10:50 PM Thread Starter
hjlueth0001
Thanks for the help guys, I'll be sure to get a new battery. I know the alternator is fine though, because while the battery wasn't holding a charge, the alternator was still trying to put a charge to it. Thanks guys.
Starter Relay or Starter Solenoid questions drespecki YJ Wrangler Technical Forum 7 01-22-2010 10:33 AM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 10:22 AM
Starter or Starter Solenoid problem? Mike in IL TJ Wrangler Technical Forum 5 08-19-2007 12:35 AM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 01:34 PM
starter relay, solenoid problems jamerkel YJ Wrangler Technical Forum 1 07-25-2002 11:58 AM
