Starter not starting? Read this! - JeepForum.com
post #1 of 34 Old 09-08-2009, 07:24 AM Thread Starter
AER2007
I have seen many posts on this board with people incorrectly diagnosing starting issues, or giving advice that requires a lot more wrench turning and guess work than necessary. I figured I could make a little diagnostic write up to better inform people about how to test the system, and how it works in our Jeeps.
One thing to keep in mind is that the starters ONLY job is to turn the engine over. If your starter is cranking over the engine but it's not firing, your problem lies elsewhere.
The first step in properly diagnosing the starting issue you are having is to verify your voltage. If you are not getting enough power to the starter, you cannot properly start your jeep. Grab a voltmeter (NOT a test light, those are useless here), and a twelve pack. I prefer Guinness or New Castle, as they have a high Jive-osity ratio when working on my jeep, but anything will suffice. You may need a friend to give you a hand turning the key while you take some voltage readings.
1. First, we start with the battery. This is where you get your power from. If you have a load tester, hook it up to the battery posts (there is no need to remove any cables). Make sure your battery has a decent charge. 12V - 12.6V is acceptable here.
2. With your voltmeter on the batter posts, turn the key to the start position, and read what the voltage drops down to at the battery posts. If it drops below 10.5V or so, you either have a bad connection at the posts, low battery, or a bad battery. Make sure the posts are free of corrosion, charge it up, throw a new one in, do whatever. If you have the battery tested at a shop, keep in mind that you cannot correctly test a battery without it being fully charged. Once you have your freshly charged/new battery, throw that sucker in and if you still don't start, proceed to the next step.
3. Have you cracked one open yet? If not, do so.
4. Once you have verified that your battery is able to produce enough current, you need to check your feeds to the starter. We will start with the ground, since that is more common of a failure from what I have seen. With your volt meter, put the positive lead on the positive battery post, and the negative lead on a clean metal surface on the starter body, or the solenoid mounted on it. Any clean metal surface on the starter will suffice. Verify that the voltage reading you get at rest is the same as the battery reading at rest. Have your friend (you gave him a beer too, I hope) turn the key, and note the the lowest point the voltage drops to. Remember the reading we got when trying to crank at the battery? You do not want to see more than a 0.5 volt decrease at the starter when cranking. If you drop more than that, you have resistance in your ground circuit. Trace it back until you find the point where the voltage is being lost. That includes the cable, the connection at the battery end and the end that mounts to the motor, the connection where the starter mounts, everything in between. If you are having trouble tracing it back, just start at the starter and move the volt meter back one connection at a time until you get a good voltage reading. That will tell you exactly where you are losing your ground. Once everything checks good, we need to check the live feed to the starter.
5. Put the negative lead on the negative post of the battery, and the positive lead on the large post of the solenoid on the starter, where the live batter cable runs to. Perform the same tests as we did on the ground cable to check the live feed. Everything good? Let's check the ignition feed now.
6. Keeping the negative lead where it is, put the positive lead on the small wire connected to the starter. This is the ignition terminal, when you turn the key to the start position it sends power to this terminal to engage the starter. Take the same readings as we did on the cables. Note that this wire should ONLY be live with the key in the start position. If you have low/no voltage here, then you are not getting power through the ignition, and should check for a bad/broken wire, ignition switch, etc. In a Manual jeep, check to make sure the Neutral Safety Switch and related wiring is in working order.
7. If you have sufficient voltage present at the starter and still not cranking properly, then your issue is most likely the starter (or a seized engine). More than likely you can replace the starter and be on your merry way.
COMMON STARTING ISSUES:
RAPID CLICKING: 99% of the time it is low voltage to the starter. Check battery and feeds as detailed above. Basically you have enough current to engage the first coil in the starter solenoid, which pulls the plunger in and engages the drive into your flywheel, but not enough to power the holding coil which keeps it in while cranking. This causes the solenoid to release, and the re-activate since the current in the system is brought back up. this will happen rapidly, hence the click-click-click-clicking. VERY rarely it is an imbalanced solenoid on the starter. The voltage readings above will diagnose it properly.
NO CLICKING AT THE STARTER: Check for a loss of ground to the starter, or a loss of voltage at the battery. Check the ignition terminal on the solenoid for power when trying to start. If none of those circuits have any issues, the starter is bad.
JUST A CLICK:
Again, verify the voltages. The solenoid could have enough power to engage and feed current to the starter, but a loss of current in the ground/cable/battery could be causing the starter to not crank properly. If the voltages are fine, change the starter.
STARTER SPINS, BUT DOESN'T CRANK THE ENGINE: The drive in your starter is blown or the gear is chewed. Change the starter (or drive if you are so inclined). Also check the teeth on the flywheel, make sure they aren't torn up. It is also possible (but unlikely under normal circumstances) that your drive shaft is snapped, or the planetary track in the starter is worn, in which case a new starter is in order.
STATER STAYS ENGAGED AFTER ENGINE STARTS: If the starter stops spinning when the key is off and the engine stops turning, check the ignition feed to the starter, make sure the ignition switch isn't faulty and supplying voltage to the starter when not in the start position. The drive could also be binding mechanically. If the engine stops turning and your starter is still spinning even with the key off, you have a low voltage issue. Basically what is happening is you have enough voltage to crank, but it is low enough that the contact disk in the solenoid is welding itself to the contacts due to heat from loss of amperage. Find your voltage drop in the battery/cables. I also suggest changing the starter/starter solenoid, as this causes the contacts to become distorted and chewed, and will cause problems in the starter.
CRANKS SLOW: Again, check voltages, change starter if necessary. Notice a pattern?
A NOTE ABOUT HAVING AUTOZONE TEST YOUR STARTER.
Autozone, C.A.P. and the likes cannot PROPERLY test your starter. I say this because every store I have seen test them just puts power to it to see if it spins and to check that the drive pops out. There are many problems that cannot be determined through that alone. Worn or gummed up brushes, a slipping drive, and worn contacts in the solenoid are just a few of the issues that can make a starter turn over on the bench, but not in your jeep. If have yours tested and they tell you it is fine, take it with a grain of salt.
If you have any questions, feel free to post them here or shoot me a PM
You're starting to be beyond pedantic and that's my job, quit trying to take it from me.
Originally Posted by ageorgakis View Post
No, I wasn't being comical. I'm being perfectly honest. I don't have any dyno tests. But you can FEEL the difference!
AER2007 is offline
post #2 of 34 Old 09-08-2009, 07:54 AM
NH2112
Awesome write-up, it should be a sticky!
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #3 of 34 Old 09-08-2009, 04:01 PM Thread Starter
AER2007
I dunno about a sticky, but at least I can link to it when people have problems instead of re-typing instructions
AER2007 is offline
post #4 of 34 Old 09-27-2009, 01:03 AM
Bird1346
Hey, I have a 99 4.0 wrangler, that I have currently used multiple 12 packs over multiple days on.lol. I have good voltage, it is turning over strong, but not starting. I do not have fire from the coil to the distributor. I replaced the dis cap, rotor, and coil today. still no luck, Im out of ideas. please help.
Bird1346 is offline
post #5 of 34 Old 02-21-2011, 10:06 PM
basssolow5
ive had another problem with my starter that i think should be put up there somewhere. i had just a single click, but no turning over. no drops in voltage anywhere as the starter wasnt drawing anything. i pulled the starter out, took the solenoid off and found it completely covered with rust. i think that happened because i got stuck in a river about 1 or 2 weeks before. the water probably rusted out the internal contacts. i tried sanding it down to the metal, still only a click. replaced it, worked great. i think it should be up there somewhere(maybe?) because any jeep could get stuck in a river. but only when the driver is being stupid... much like me!
colorado jeep club member #730
stimulating the economy one part at a time!
basssolow5 is offline
post #6 of 34 Old 05-04-2011, 09:12 PM
aa192800
Where's a good place to get a new starter?
aa192800 is offline
post #7 of 34 Old 05-16-2011, 03:22 PM
TJeep_1999
2015 JK Wrangler
Looks like I have plans for tonight after all... Hoping this helps me figure out where the issue is...
TJeep_1999 is offline
post #8 of 34 Old 05-16-2011, 03:58 PM
hefightsfire
Bookmarked! Good job man!
"The problem with quotes on the internet is that you never know if they are real."
Abraham Lincoln
hefightsfire is offline
post #9 of 34 Old 07-06-2011, 03:12 PM
Rob_Feature
Great post just what I needed. Just one comment: When one of the above tests fails, its not clear how to tell what's at fault.
For example, the #5 item (neg. battery post to pos. starter post) failed for me...does that mean my positive cable from battery to starter is bad?
A little clarity on what each of the failed tests means would be great.
Rob_Feature is offline
post #10 of 34 Old 10-04-2011, 02:42 PM
ryanwhiteaker
ryanwhiteaker's Avatar
This is perfect! Nice job! I replaced my starter and started blowing the ignition fuse when I would turn the key, nothing came from the starter. With the key in the ON position, everything lit up but there was no power going to the starter terminal/harness/plug. I just wired the starter up into the cab and made push button start because I was too lazy to do any circuit testing. Maybe I will finally get to it this weekend.
STOLEN - '01 TJ sport-Wayyyy to much money invested -
TRADED IN - '07 WK Limited 5.7L - OME HD kit l Rusty's .25" strut spacer l 255/75R17 l Spidertrax spacers all around l Powerwire l K&N CAI l JK MOAB black wheels l Rola Rack with Yakima spare tire mount system l 4xGuard belly skid l 4xGuard Rocker Guards
335I M Sport (e93) - plenty of mods so far :)
Originally Posted by EagleRiverDee View Post
it appears that REAL Jeeps leak fluids everywhere, spend more time parked in pieces than being driven, rust completely through the floor boards, gauges don't work, heaters don't work etc...
ryanwhiteaker is offline
post #11 of 34 Old 07-16-2012, 10:25 AM
midmichmark
Thanks for the Diagnosis Guide ;-) My Jeep (1995 jeep yj 4 cylinder 5 Speed) just started to have an intermittent starting problem - seems like it may be related to heat? but don't know for sure, it's been mid/upper 90's all week! I'll put the key in the ignition, turn it on - everything lights up - but when I go to crank it - there is no noise of any kind at all. I'm going to buy a volt meter today! I think it could be my battery? I replaced it about six months ago, but didn't notice the tightening bolt on the negative terminal was rusted out in the middle - both ends were there so it looked normal without my glasses on when i wiggled the terminal off/on the post to replace the battery. I think maybe my battery may not be fully charged?
midmichmark is offline
post #12 of 34 Old 07-16-2012, 11:57 PM
BStro
Thanks for the write up! My '05 Rubi wouldn't start and I searched the forum for a solution.... found this and saved myself a lot of time and money. Confirmed the problem was the starter, picked up a new one at my local NAPA for $90 (w/AAA discount) and was up and running in no time.
Thanks again!
Bill
BStro is offline
post #13 of 34 Old 08-28-2012, 03:01 PM
Ramoon2
Newbie
I have a Limited Jeep Liberty 2008, we just love it, but if I can not get this problem fixed, I will have no choice but to trade it in. I had bought it used with low miles in early 2010. thinking now the previous owner had the same issues with no solution. Starting issue is random seems to happen more in cool or wet weather but not always.when you try to start it, it just clicks with a small starter turn that all that happens. most of the time 3-10 turns on the ignition and it starts, and other times never, until you tow it to the shop , than it will start, it has left me stranded 2 times. I have taken it into the shop many times (5 at $100 each) they check out the battery and even though it tested good, I replaced it anyway ($163.00), they replaced the starter, I verified it was new by looking at it. When I take it in even to the dealer and it starts for them they look at me and say its fine, so I guess I towed it down there for no reason. I believe somewhere is a short and the tow truck ride helped it reconnect. So now I am thinking that I need to swap out the jumper cables for my jack and next time jack it up and drop it fast a few times may help it start. I am telling them it is happening but if it don't happen for them I guess its not happening, I don't know what else to do. I am at a loss any help would be great, but I cannot keep an unreliable vehicle and will not purchase another from that dealership if the most they will do is try and start it, if it starts it's fixed.
Ramoon2 is offline
post #14 of 34 Old 08-28-2012, 03:40 PM
NH2112
I'd check to see if you're losing power to the "start" terminal on the solenoid or starter. Another person with a test light can do this when the problem happens. If you are losing power I'd look at all connections & cables from the battery to starter, and the neutral safety switch, ignition switch, and their associated wiring.
In defense of the shop, what do you want them to do when you bring it in with the problem and it starts normally for them? Try again? How many times? 10? 50? 100? What happens when they give it back to you and it doesn't start on try #101? You can't fix what isn't broken when you check it out. If I had a dollar for every time I've turned ignition switches till my fingers went numb, gave the machine back to the customer with a "could not duplicate problem" writeup, and got a call soon afterward saying "it won't start again!", I'd have a lot of dollars!
Phil
NH2112 is offline
post #15 of 34 Old 06-10-2013, 04:26 AM
VonBraun
1974 CJ5
Hey Ramoon2 it may be that your ignition control module is faulty although its symptoms are problematic relative to heat shutting it down every 20 minuts or so, sometimes those modules in the distributor can be eratic. However, there is a higher probability that your problem is linked to your Neutral Control Switch which controls your Starter Relay's ability to send current to your Solenoid Relay or it could be the Starter Relay itself being intermittent. Thus I would recommend that you By Pass your Neutral Control Switch and REPLACE your Starter Relay and you might be ok. Remember that Starter Solenoid Relays and Starter Relays are two seperate critters.
A journey of a thousand days begins with a first step, with arms wide open while looking straight up and touching heel to toe, and saying your alphabets backwords and your eyes following that little pin flashlight....................
VonBraun is offline
My starter stops starting. LittleGreenJeep TJ Wrangler Technical Forum 9 10-21-2009 09:12 PM
New Battery/Starter. Not starting huntandfish YJ Wrangler Technical Forum 12 04-06-2009 06:23 PM
Problems starting. starter works but nothing else. PhilipSandgren YJ Wrangler Technical Forum 5 03-12-2009 04:47 PM
Starting trouble (battery, starter, ????) biz482 YJ Wrangler Technical Forum 3 02-29-2008 10:03 PM
Jeep wont start AGAIN. Is it the starter? Please read on for symptoms 97GreenTJ TJ Wrangler Technical Forum 11 08-04-2005 03:03 PM
