Starter Issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Starter Issue
Dual Color LED Light Bars White/AmberFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/Bla
Unread 04-28-2013, 08:15 PM   #1
saloom86
Starter Issue
Hello Everyone,
I just completed an engine swamp on a 2000 Jeep Wrangler 4.0. When I try to start the Jeep, the starter does not engage the flywheel. I've put a new starter on and same issue. I popped the clutch on the Jeep and the engine fired up and ran perfect. Battery is brand new. Any help or tips would be much appreciated.
Thanks,
Phil
saloom86 is offline   Reply With Quote
Unread 04-29-2013, 10:14 AM   #2
wushaw
Rockin jeep
wushaw's Avatar
You verified the starter is working? The bendix is kicking out? There are teeth on the flywheel?
wushaw is offline   Reply With Quote
Unread 04-29-2013, 10:21 AM   #3
saloom86
Flywheel is good, but I don't believe the bendix is kicking out. I think it might be an electrical issue that is causing the bendix not to kick out. Thoughts?
Unread 04-29-2013, 10:26 AM   #4
NotURMailman
Did you possibly put the soleniod wire on the wrong terminal on the starter?
Does the starter spin when you turn the key and just not kick out?
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
