starter or battery? - JeepForum.com
post #1 of 9 Old 09-30-2010, 05:51 PM Thread Starter
Utfan010
starter or battery?
okay so when i got in my jeep today i tried to start it up, i didnt turn over. so i got out checked the battery it seems to have good connections. but i got back in and truned the key and a loud grinding noise was comin from under the hood, i personally think its the starter. the battery is only one year old, so is there any way i can check if its the starter?
when in doubt, press the skinny pedal!
Utfan010 is offline
post #2 of 9 Old 09-30-2010, 05:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
99 times out of 100, that problem is either a bad battery connection or a weak battery. You can't tell if the connections are bad by just looking at them. Period. You absolutely have to remove both battery connectors, wire brush them and the battery posts, and then reinstall them tightly to determine if the connections are at fault or not. If that doesn't do the trick, take the battery to your local auto parts store and have it load tested.
I would bet $$$ your starter is fine.
Jerry Bransford is online now
post #3 of 9 Old 09-30-2010, 06:04 PM Thread Starter
Utfan010
alright thank ya man, im gonna take the battery out tonight and clean everything and see what that does, weve had a lot of raining lately and i know the battery got pretty wet at one point, but that wouldnt do too much to it right?
Utfan010 is offline
post #4 of 9 Old 09-30-2010, 06:06 PM
Jerry Bransford
Administrator
No need to actually take the battery to clean up the connections, you can leave it mounted in the Jeep while cleaning them. Only remove it and take it to an auto parts store for testing if cleaning and tightening the connections doesn't help.
post #5 of 9 Old 09-30-2010, 06:07 PM Thread Starter
Utfan010
also after about an hour of sittin there, when i got back with some jumper cables it started up with very little problem without the jumper cables
Utfan010 is offline
post #6 of 9 Old 09-30-2010, 06:14 PM
Fusco
2016 JK Wrangler
Had same issue......it was the battery.
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #7 of 9 Old 09-30-2010, 06:16 PM
Jerry Bransford
Administrator
That alone very likely indicates an intermittent battery connection, clean 'em.
post #8 of 9 Old 09-30-2010, 07:22 PM
daveg13try2
Spend $10 and pick up a cheep volt meter for your tool box. Comes in handy in times like this.
daveg13try2 is offline
post #9 of 9 Old 10-01-2010, 10:33 AM Thread Starter
Utfan010
the battery is good, and all connections they said were good. its gotta be the starter? cant having a lot of water on it damage it?
Utfan010 is offline
battery , electric , starter
battery or starter?? help Ridgejeep YJ Wrangler Technical Forum 14 01-19-2010 08:08 PM
Battery or starter? redwolf_747 TJ Wrangler Technical Forum 9 06-18-2009 06:25 PM
starter or battery? mmasuperman12 YJ Wrangler Technical Forum 4 06-16-2006 06:04 PM
Starter or Battery? vdubstreets YJ Wrangler Technical Forum 19 05-28-2006 10:36 PM
Battery-starter or what not sure mule-brothers YJ Wrangler Technical Forum 2 08-19-2004 06:08 AM
