Started building my Belly up today...
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
Some Call me RockDog
So far it's cost me $50. I cut the shape out of 1/4" plate that I bought. Tomorrow or some time this week depending on weather, i'm going to drill the holes and cut the cusset support material out and mock it all up. I will have photos later.
My eventual plan is to put UHMW on the underside to help slide over things a lot better. I hope to have everything finished for this weekend and I don't have a welder at home. Hopefully It will get finished. I also brought the exhaust mount at the Tranny down about an inch or so. I could bring it down about another 1/2" to 1" if I need the extra room, but I don't think I will need it.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#2 |
Here's what i have so far... Used a plasma cutter yesterday to cut the bulk of it and then today I cleaned it up and realized that I needed to cut a whole lot more off to make it all fit together.
![]() ![]() I'm going to drill the holes, make a mount (needs to be angled), and weld the gussets and some pieces to drop it a little. This thing is heavy and I think I must have lifted it up to check the fit atleast 15 times today... no joke. I am exhausted from cutting, lifting, and grinding today.
#3 |
Great idea. I can't wait to see the finished project.
2010 2dr Rubicon - Mango Tango! Colorado Jeep Club Member #11 Former Jeeps: 2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7 |
#4 |
lookin good so far, definitely interested to see how the UHMW will work out for ya...
Semper Fi |
#5 |
If you traced this on a piece of poster board or something, rolled it up and shipped it to me in a mailer tube I bet I would pay for it.
I bet more people would pay for it too. I could do this for free at my dads work. |
#6 |
I can make one. My back cuts are a little off compared to one another. One is more angled than the other. The front cut outs are because I wanted a little more protection and They hit my front clayton mounts. Also I think my holes are off by about 1/16-1/8 of an inch from across the frame, but they are good on the same sides. ALso, I think the mounting holes are different with 97-02 and 03-06TJ's
#7 | |
Thats going to be quite the lipo tummy tucker
2004 TJ | 5'' on 35x12.5's | Currie HD Steering| Smittybilt tire carrier | 4.56's | 1988 XJ | 6'' on 33x12.5's | Locked and Loaded | Quote:
#8 |
It's probably going to be about an inch to an inch and a half hanging down. I would like to take it up more, but with only a 1" BL I don't have much more room and I don't have a HP rear end so my pinion angle is pretty steep with it all the way up.
#9 |
Are you going to pick up another CV shaft for the rear? I have recently sold a few non-nessasary jeep parts and have cash burning a hole in my pocket. Plan on getting the Medic TT.
Do you happen to know how long the TW shaft is you have? As my Jeep sits, the shaft is a 15 degrees, IIRC the TW CV joint will work up to 30 degrees w/o grind work? |
#10 |
I have the TW shaft. IT has a lot of room to stretch. Once I get the TT finished, I'm going to kick the rear axle back about an inch or so, as much as I can. This will also help with the angles. I'm not sure of the angle but surely it isn't close to 30
#11 |
welded the gussets and supports on last night. 3/8 on the ends with the frame holes, 1/4 across the middle where it attaches to the tranny, I also added some in the front as well as some in the rear. I may end up cutting the rear part off because it doesn't really protect anything and to reduce weight.
#12 |
I got the first coat of paint on the top side tonight.
![]() ![]() so far it's cost me around $60-65 including the longer bolts and cut off wheels My Major in College is Mechanical engineering... I think once again I have over engineered something... It's heavy, but I don't think it's going anywhere.
#13 |
Are you using countersunk hardware on the trans-mount too? With the one inch body are you having to lift the trans much to get the flat skid? I was thinking of doing almost the same thing but with a clocking ring for the 231.
#14 |
on the Trans mount, I put a piece of 1/4" on the top that acts as a spacer as well as a reinforcement. That way I can use the original hardware. I am going to get a 1.25 or 1.5" hole saw today so I can counter sink the hardware for the trans as well as the frame mounts. I figured that if i'm going to buy one, i'm going to buy a hole saw that works for both of them and be done with it. The trans will take priority on my time today because I need to get it finished today and mounted so that I can take it this weekend.
I took much of my sesign from this... ![]() ![]() it's going to hang down about an inch and a half with the spacers. eventually i would like to get a different trans mount to allow me to lift it up even more, but that's around $130 and i don't want to spend it on something that i don't "need"
#15 |
Looks good. I really don't think anyone would complain about an inch and a half for $65 vs 1/2 and inch for $500.
![]() I'd be interested in building something similar for myself, if you're going to make your plans public for it, I'd love to get a present in my JF inbox with some measurements. ![]()
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
