standard gear ratio - JeepForum.com
post #1 of 5 Old 04-17-2011, 02:12 PM Thread Starter
geo2toy
standard gear ratio
Ok so going to re gear but need to find out what I have to start with so I can work out if i need new cases!
so 2000 year 4.0ltr TJ
with stock Dana 30 front
dana 44 rear with traclock
running a 5 speed stick shift
This is a UK model so may be different from you guys.
Anyway how can I tell I have both axle tags intact but its just numbers and letters to me none look like a ratio
Any ideas?
Cheers
geo2toy is offline
post #2 of 5 Old 04-17-2011, 02:25 PM
crusher242
Hard to say. I've never even heard of a D30 traclok. I would still guess 3.73.
Hold onto something... Quick!!!
crusher242 is offline
post #3 of 5 Old 04-17-2011, 02:30 PM
Liquid741
http://www.jeepforum.com/forum/f96/w...-sure-1074407/
check this thread...should help you out if you want to know for sure. hope this helps!
Jeeps are like boobs...I always look at them, regardless of condition
Liquid741 is offline
post #4 of 5 Old 04-17-2011, 02:45 PM Thread Starter
geo2toy
OOPS Typo!
I think it is 3.73
geo2toy is offline
post #5 of 5 Old 04-17-2011, 02:51 PM
freeskier93
The first three numbers on the second line of the tag is your gear ratio. So 307 is 3.07. 373 is 3.73.
freeskier93 is offline
bigger tires, the right gear ratio vs. speedo gear krafalco YJ Wrangler Technical Forum 3 08-16-2011 07:58 PM
2?'s Which speedo gear and actual gear ratio maxum3300 TJ Wrangler Technical Forum 6 01-15-2010 07:40 AM
Gear Carriers for gear ratio swap bwiencek YJ Wrangler Technical Forum 1 05-04-2006 10:52 AM
33'' With a 3.5 RE Standard 3.07 Ratio Willit work smileyox TJ Wrangler Technical Forum 5 04-01-2005 09:38 PM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 10:52 AM
