Stalling out - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Stalling out
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE
Unread 06-13-2014, 06:41 PM   #1
TJJeepinguy
Stalling out
Hi,
I have a 97 4.0 that has started to stall out and cut off. Before the cutting off began it would hiccup as if the fuel got interrupted for a brief second. And even before the hiccup's it would seem to try and stall for a while as the fuel level would get low. The hiccup's would happen while I as on the throttle. The cutting off has happened both as I was on the throttle and as i had let off to slow down to a stop. It also did this with the tank full and close to empty. I could imminently restart the Jeep without any issues and continue down the road.
Does this sound like a fuel pump issue? Something in the tank itself? Or something totally different.
Thanks
TJJeepinguy is offline   Reply With Quote
Unread 07-14-2014, 07:11 PM   #2
TJJeepinguy
Just want to add that it is now stalling out at times when I come to a stop. It restarts without any issues. Thanks
