Stalling issue on '06 TJ - JeepForum.com
post #1 of 2 Old 03-24-2012, 07:50 PM Thread Starter
officerbrando
I drive an '06 TJ, 4 cyl, 6 speed. I have this consistent issue where I keep stalling out, but battery is still on when I am driving above 65 and my speed drops to about 55 or lower. It happens almost every time I am on the high way and slow down to that speed. It also may stall sometimes, or begin to stall other times I slow down but it consistently stalls at those speeds. I need help with any legitimate ideas of what it may be. My check engine light is on, but after checking with autozone it shows that the light is on because of my power steering, which I just had replaced. My air filter was filthy, and I changed that thinking that my engine was just choked for oxygen when slowing down, but that was not the case. Any help is appreciated.
officerbrando is offline
post #2 of 2 Old 03-24-2012, 09:11 PM
77351wcj5
A wild guess would be that your ckp sensor is failing. A crank sensor does not always throw a code, and sometimes it will try to warn you before it dies. How many miles on your rig?
77351wcj5 is offline
1995 YJ 4.0L Stalling Issue. SOS help cycule YJ Wrangler Technical Forum 3 10-10-2011 11:18 AM
2.5 stalling bogging issue busajoe YJ Wrangler Technical Forum 4 03-27-2009 07:25 AM
89 YJ stalling issue- tell me if I'm on the right path jdrambo YJ Wrangler Technical Forum 8 01-14-2009 06:53 AM
Stalling Issue Flyersdjh TJ Wrangler Technical Forum 1 07-27-2008 02:27 AM
Jeep stalling issue vdubstreets YJ Wrangler Technical Forum 4 05-13-2006 10:07 AM
