squeky engine? - JeepForum.com
post #1 of 5 Old 10-18-2010, 12:36 PM Thread Starter
wrangler793
squeky engine?
hey everyone, i went off roading yesterday and i was going through some water and it got on my distributor and my engine started to miss fire and the check engine light came on but then it was fine after it dried and the check engine light went off. but today i realize that there is something squeaking in my engine compartment. im pretty sure its my belt squeaking on one of the pullys. its wen you rev the jeep that you can hear it. maybe the belt is just shot or it will go away because i just got dirt on it. whats your opinion on what i should do?
wrangler793 is offline
post #2 of 5 Old 10-18-2010, 01:24 PM
WakeUpJeepin
Take off the belt; inspect it thoroughly; put belt back on, and torque properly.
If the problem is still present after you complete the aforementioned steps, seek further advice.
˛_______
/ l˛[____]˛
l▫▫▫▫L 0llllll0-
()_) ()_)-○-)_)
WakeUpJeepin is offline
post #3 of 5 Old 10-18-2010, 01:28 PM
frAnken_rubi
its probably your tensioner. This has happened to me before, and i just let it squeak until it went away, which was about a month.
frAnken_rubi is offline
post #4 of 5 Old 10-18-2010, 03:13 PM
Tank55
Could be the alternator bearings, I had the same problem last winter after I got my jeep wet a few times and it started getting cold outside. I put in a new alternator and upgraded the belt from the cheapo factory serpentine belt to a Gator belt. I also lubed up the belt tensioner.
-The Tank
"Life is too short, Forgive quickly, Love truly, Laugh uncontrollably, and Never regret anything that made you smile."
Tank55 is offline
post #5 of 5 Old 10-18-2010, 03:26 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Pressure wash then recheck.Anytime your out off roading through dirt,mud,water, sounds will arise.After it's thoroughly cleaned, then pinpoint the area of the squeak.If you have to... use a mechanic stethoscope, a wooden dowel, or a long screwdriver to your ear carefully!WD-40 is always good to disperse water. It's nice to pressure wash after having fun,and helps immensely.Have spray lubricants at hand and plenty of grease for lubing all zerk fittings and such.
GOLENJEEPTJ is offline
belt , engine , pully , squeaky , water
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 12:23 PM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 08:00 PM
1984 CJ7 6 cyl 258 engine swap into 1988 wrangler with 6cyl 258 engine? xavier27 YJ Wrangler Technical Forum 0 07-29-2010 03:08 PM
SQUEKY springs kjg26 TJ Wrangler Technical Forum 1 08-10-2003 03:09 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
