Quantcast squeeling noise!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > squeeling noise!!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 07-24-2006, 10:38 PM   #1
bloke279
squeeling noise!!!
hey all, i havent been on in a very long time due to new marriage and work... and all that crazy stuff!
anyways, i have a problem...
on my way home from work today, on a two lane highway, i got behind a very slow truck for a distance of a few miles. he was going 30 mph. being pretty hot outside, i had the a/c on, trying to cool off form a days work. When i got the slightest bit of a chance to pass, i took it. as i stepped into the accelerator, the 4.0 gave a mild chirp. i thought it was the belt slipping, that what it sounded like anyways. i never step on the gas hard when the a/c is on, just a pet peeve. when i got back into town, i turned the a/c off, and rolled the windows down. curious about the noise, i stepped in it again, accept this time i was at a complete stop. this time the squeel continued until i let commpletely off the throttle. any guesses?
i checked the belt, it seemed to be fine, not loose either. My engine compartment is very clean, a virgin to mud. so no uneccessary wear and tear.
please help. I have a warrenty too, but i want to go in with an idea...
thanks, bryant
Full Traction 3" altitude adjustment
Warn front/rear bumper
Hesco TBS
Magnaflow CAT Back Exhaust
285/75r/16 BFG A/T on rubi wheels
Clear marker lenses
JKS discos
[COLOR=Silver][B]Silver jeep club member #76[/B][/color]
bloke279 is offline   Reply With Quote
Old 07-24-2006, 11:10 PM   #2
adp5025
cracked belt?
1999 Jeep Wrangler Sport 4.0L 5 Speed (Dana 30/186MM Front Axle,3.73 Axle Ratio,Dana M35/194MM Rear Axle)
2004 Jeep Grand Cherokee OVERLAND 4.7H.O. V8
2007 Toyota Tacoma Double Cab 4.0L V6 TRD offroad
[COLOR="Blue"][B][FONT="Franklin Gothic Medium"]Penn State University - Engineering[/FONT][/B][/COLOR]
adp5025 is offline   Reply With Quote
Old 07-24-2006, 11:22 PM   #3
drew76924
i sometimes have that too like it'l squeek for liek half a second and liek i'll lose power for liek half a sec at higher rpms but then after it will b fine >?
RIP: 97' TJ on 35's (rolled)
03' Mustang GT Turbo Vert
drew76924 is offline   Reply With Quote
Old 07-24-2006, 11:38 PM   #4
Rocky529
Jeep
Rocky529's Avatar
thanks, bryant
What year is your TJ? If it does not have an auto-tensioner, make sure it is torqued down properly (run a search to find out how).
If it's not the torque, your idler pulley may be at blame.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 07-24-2006, 11:40 PM   #5
bloke279
not a crackd belt, ive inspected it thourghly. When i get a solid kick down, and it jumps to about 3500 rpm, it does it.
I just took my buddy for a ride, and i couldnt duplicate the noise at all. Thinking back now, ive come to the conclusion that the squeel only happens when the fan clutch is on. When i was on my way home it was running, and when it did it again, i had the jeep standing still with the a/c on for the wife for about five minutes, when i left the house, it did it again. again, the fan clutch was running.
its parked for the night, if it continues, ive got warrenty, it only has 29,000 miles on it!
Hesco TBS
Clear marker lenses
JKS discos
Old 07-25-2006, 03:09 AM   #6
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
just tighten the belt an RCH and see if it happens again on a long drive.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
Feed my girlfriend.
Follow my girlfriend
Brew what you drink, drink what you brew
USN Hull number 54
Poor Boy is offline   Reply With Quote
Old 07-25-2006, 08:24 AM   #7
Rule303
Its the belt.
Rule303 is offline   Reply With Quote
Old 07-26-2006, 01:03 AM   #8
bloke279
that was my suspisions. either that or a pulley. i will give it a try! it probaby doesnt help that i just amor all'ed the engine huh? haha...
Hesco TBS
Clear marker lenses
JKS discos
Old 07-26-2006, 02:41 AM   #9
garrett
its not the belt its the a/c pully bearings its happened to me in my old 96 cherokee 4.0 when i would turn the a/c on from a dead stop or when i just start it and drive i had to replace my a/c pully bearings
garrett is offline   Reply With Quote
Old 07-26-2006, 02:43 AM   #10
Rocky529
Jeep
Rocky529's Avatar
I would use a product that is made for the engine (unless you did, and are just using ArmorAll as a way to describe it).
Old 07-26-2006, 10:23 AM   #11
Rule303
Could be the armor all! Take the belt off and you'll know real quickly if its a pulley.
Old 07-28-2006, 07:24 PM   #12
bloke279
i didnt actully use armor all, it was just a gerneral term...
haha
its not doing it anymore, i will have to wait until it gets worse i guess so i can properlly diagnose the problem... oh well...
i think its the bearings...
Hesco TBS
Clear marker lenses
JKS discos
Old 07-29-2006, 10:50 AM   #13
Rule303
Hard to diagnose over the net. A squealing belt sounds different from a bearing to me. Glad it cleared up for ya.
Old 07-29-2006, 10:58 AM   #14
dtrick
i have the same sound when my ac is on as well, mainly when i take off from a complete stop and it stops once i am at about 15mph
98 wrangler sahara
white
2 inch body lift, 4 inch suspension lift
teraflex
35x12.5 bfg all terrain
dtrick is offline   Reply With Quote
Glock Forum
