Squealing from the serpentine belt, how can I stop it? - JeepForum.com
post #1 of 22 Old 05-23-2010, 11:07 AM Thread Starter
JfirEfightErP
Hey, my 6cyl 97TJ Sport, squeals a good amount when you start it up for the first few minutes. It seems to be coming from the A/C compressor pulley area. Any suggestions on how to stop this? Can I repair/replace a pulley? try stop squeal spray products? maybe a new serpentine belt? Thanks a lot.
Firefighters find 'em hot and leave 'em wet
JfirEfightErP is offline
post #2 of 22 Old 05-23-2010, 11:11 AM
BamaBangs
I had the same problem in my '98 TJ. I had to replace the pulley on the ac compressor because it eventually locked up. It had stopped squeaking for a couple weeks and has now started back up again. I've heard to stop the squeaking you could just tighten the belt up some.
BamaBangs is offline
post #3 of 22 Old 05-23-2010, 11:16 AM
Malebolgia
Check your belt for cracks and glazing. Most of the time the squeeling is caused by a worn out belt and not a pulley. The sound is different as well. The pulley will have more of a metal on metal sound and the belt is rubber on metal. You can use the belt dressing stuff but it is just a temporary fix. The best thing to do is replace the belt if it is cracked. If it is not then just tighten up the belt and the sound should go away.
:EDIT: The reason you are hearing it in the A/C pulley area might just be because that is where it is slipping.
Malebolgia is offline
post #4 of 22 Old 05-24-2010, 07:31 AM
fduncan
Buy a Goodyear Gatorback belt. I had problems with mine, but a Mopar belt on and after a little while noise came back. But on the Gatorback belt and no more noise. I got mine at Auto Zone.
fduncan is offline
post #5 of 22 Old 05-24-2010, 07:50 AM
dvdwly
I had that problem a few weeks ago. After I replaced the belt the squeal went away.
dvdwly is offline
post #6 of 22 Old 05-24-2010, 10:03 AM
wlmonk
I had a squeal on mine, but it didn't sound like a BELT squeal. And it wasn't. It was the bearing in the idler pulley. I guess I'd have to hear your squeal to give you my opinion. Belt squeals and bearing squeals are different.
wlmonk is offline
post #7 of 22 Old 05-24-2010, 10:18 AM
MO2500
How many miles? Original serpentine belt?
I would check for cracks and glazing on the belt as said above. If it's the original belt i'd change it and your squeal will likely go away.
Instagram: @omsmike
MO2500 is offline
post #8 of 22 Old 05-24-2010, 11:59 AM
stratons_tj
Not to hi-jack...but I too have a squeaky belt.
How do I go about tightening it to see if that's it before buying a new belt?
"Tilt your knee slightly out the door, its like Ram Air for your goods." - Flatlander
stratons_tj is offline
post #9 of 22 Old 05-24-2010, 07:18 PM
Sahara01
I had a bad idler pulley cause squealing before it decided to give up. However, sometimes it's just glazing etc on the belt. I learned a trick to cure the problem, I am going to say you need to be very careful when doing this though, make sure no loose clothing, sleeves, jewelry etc. You take a wire brush ( the mini ones are great for this), with the jeep running, place it on the top of the belt in a safe location, do the same on the underside, if it is just a glaze type problem the squeal will go away. I find belt dressing etc., messy and most times doesn't even work.
Again be very careful as the motor needs to run, and you will be getting the brush into a location you could easily get hurt if you are not paying attention.
Shortbus Offroad Team #242
sponsored by
, GOODYEAR TIRES,
, Solid Axle Industries, Genright,
Sahara01 is offline
post #10 of 22 Old 05-24-2010, 07:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Before I tell you how to tighten the belt, check the belt's tightness first by pushing hard on it with your thumb at its widest unsuppored distance, that part that runs to the PS pump. It should not deflect more than about 1/2" if you push hard (!) on it with your thumb. If it's not loose, something else is likely squealing.
To tighten a '97 TJ's belt, first loosen the big black anodized nut that holds the PS idler pulley to the bracket. Then turn that long vertical bolt that is on the PS pump bracket which will move the pulley up to tighten the belt. Then retighten that big black anodized bolt to hold the pulley in place on its bracket.
Jerry Bransford is offline
post #11 of 22 Old 05-24-2010, 08:07 PM
kloppk
Ditto - I went thru the same issue with a squeeling serp belt on my 97.
At frist I tried a new standrad belt... no luck, still squeeling even after tightening it properly and even a bit beyond.
Someone then recommended the Gatorback. Popped it in and no more squeeling.
kloppk is offline
post #12 of 22 Old 05-24-2010, 08:39 PM
Kiwi_TJ
Check the idler pulleys, I replaced the bearing on mine, only cost $10 for the bearing and half an hour to remove the pulley, press out the old bearing, and press in the new one vs $145 from the dealer for complete new idler.
I have no AC on my Jeep so not sure how you would fix that if it was the issue.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #13 of 22 Old 05-24-2010, 11:35 PM
J03_TJ
If it was a regular old belt you could run a bar of soap on it first. Serpentine belt don't know.
J03_TJ is offline
post #14 of 22 Old 05-25-2010, 03:57 AM
sportcoupe
2017 WK
Carefully use a small wire brush on the inside of the serpentine belt while the engine is idling. Your squeak will disappear.
sportcoupe is offline
post #15 of 22 Old 05-25-2010, 09:07 AM
PeteYJTJ
Ditto X2. Gatorback is where it's at. I don't buy cheap belts anymore.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
belt , serpentine , squeal
Fan belt squealing fix and others staufson YJ Wrangler Technical Forum 4 02-10-2010 07:19 AM
Brakes Won't Stop SQUEALING cjkwiatk TJ Wrangler Technical Forum 9 01-19-2009 04:13 PM
Belt is squealing and I can't figure it out Cbaughn YJ Wrangler Technical Forum 7 01-12-2009 08:11 AM
Squealing fan belt? RockyP TJ Wrangler Technical Forum 3 08-01-2005 12:15 PM
