Squeal when in 4wd - JeepForum.com
post #1 of 5 Old 03-17-2010, 01:08 PM Thread Starter
skyscooter
Squeal when in 4wd
Went out last weekend and only when in 4wd i got a squeal that got louder along with higher rpm and it was some what itermitten. Sounds like it's coming from the front or under T/C shifter. Kinda sounds like a bad bearing, but I just had knee surgery and can't really get under there to check things out just yet. Probably shouldn't have been out wheelin either, but a month in the house sucks! It is a 2005, 4.0, 6 spd, D30, D35, with a 3" lift and T/C drop. Thanks all.
I'll keep my money, my freedom, and my guns and you can keep the "change"!
skyscooter is offline
post #2 of 5 Old 09-25-2012, 06:55 PM
hughes278
This is happening to my jeep, can anyone tell me what could be the problem and how to check/fix it?
hughes278 is offline
post #3 of 5 Old 09-27-2012, 09:22 PM
hughes278
Bump
post #4 of 5 Old 09-29-2012, 05:51 AM
4banged
I'll bump for you, have you checked/changed the TC fluid?
4banged is offline
post #5 of 5 Old 09-29-2012, 08:55 AM
hughes278
I have not, i dont really know too much about mechanical things. If that could be whats doing it i guess i could you tube how to change it.
AX-15 Squeal letitloose06 YJ Wrangler Technical Forum 5 03-05-2010 01:08 PM
Fan Squeal rjt36 TJ Wrangler Technical Forum 12 08-31-2007 10:24 PM
Squeal?! KU krawler TJ Wrangler Technical Forum 8 04-07-2006 11:10 PM
squeal like a pig K&VRubicon TJ Wrangler Technical Forum 7 04-02-2005 10:49 AM
name that squeal! jayburd8 TJ Wrangler Technical Forum 5 11-30-2004 03:21 PM
