squeaky tj - JeepForum.com
post #1 of 8 Old 07-30-2003, 10:31 PM Thread Starter
OlllOTJ
squeaky tj
so my tj squeaks at low speeds and it's realy starting to get to me. i have a 2 inch bb and 32's. its realy only in first and goes away at like 25 mph. it doesnt squeak when im not in motion flexing the suspension. do you guys have any idea what needs lubed? almost sounds like breaks are hung up in the front. plz help
1998 Jeep TJ SE,35x12.50. 15, 8.8, 4.88, Detroits
HacknTap SYE. Fabtech Rocker Protection.
OlllOTJ is offline
post #2 of 8 Old 07-30-2003, 11:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Passenger-seat mechanism? Mine does that like once a year until I spray the mechanism with a lube. Before I finally figured out the squeak's source, I couldn't tell where it was coming from and for a while, I thought it was in the suspension.
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 8 Old 07-31-2003, 07:03 AM
Gatorback
This may be a long shot...
Check the seat belt retractor. I had a squeak at low speeds, too. Thought is was the suspension but it was real inconsistent. Finally realized the squeak occurred when I was leaning forward in my seat, causing the retractor to spin and let seat belt out.
2000 TJ Sport
4.0L - 5 speed
31x10.5's on 15x8's
Gatorback is offline
post #4 of 8 Old 07-31-2003, 08:05 AM
JPJeep
JPJeep's Avatar
Search for Axle seal
And 'angry sparrows' on the TJ Forum.
Mine is still squeaky but I haven't had a chance to bring it in yet.
I did see a post a few weeks ago about this.
Let us know what you find 'cause I'm next!
Thanks,
Jim
2002 Wrangler Sport Shale Green Tan Top
Dana 44 Rear Axle/ 30" Wrangler AT Tires
Add a Trunk/ Kenwood WOOX Subwoofer
Alpine head and 12 Disk CD Changer
Daily driver waiting for first beauty mark!
JPJeep is offline
post #5 of 8 Old 07-31-2003, 08:38 AM
Jerry Bransford
Administrator
It took a while for me to figure that one out too but that squeaking is actually the sealtbelt being drawn over the plastic retractor cover belt slot, much like a violin bow being drawn over a string. I'm taking a Dremmel tool to the seatbelt opening and enlarging that side of it slightly when I can get around to it.
post #6 of 8 Old 07-31-2003, 10:30 AM Thread Starter
OlllOTJ
no it is definatly coming from the front axle
OlllOTJ is offline
post #7 of 8 Old 07-31-2003, 10:35 AM
Jerry Bransford
Administrator
Then I'd bet a healthy amount of $$ that it is the CV joint on the front driveshaft. Do a search in the various Jeep forums under "angry sparrows" and you'll find a lot of info on that problem.
post #8 of 8 Old 07-31-2003, 11:17 PM
RckyMtnTJ
Jerry's right.. likely your ball socket kit in the front driveshaft.. When mine is going, it squeaks at speeds over 10mph and under about 40mph. It is a rotating squeak. Its often referred to as angry sparrows.. If you go to www.stu-offroad.com there is a really good writeup on rebuilding the front driveshaft.. You could try to drop your front driveshaft and see if the squeak goes away.
HTH,
98 TJ with some stuff
RckyMtnTJ is offline
Sqeaky-squeaky-squeaky FT 4" SA lift phylodog TJ Wrangler Technical Forum 0 08-17-2009 09:20 PM
squeaky all over cujo3969 YJ Wrangler Technical Forum 3 06-23-2009 09:48 PM
Squeaky something Ben1993 TJ Wrangler Technical Forum 2 02-22-2009 01:28 PM
Squeaky Squeaky devildog0331 TJ Wrangler Technical Forum 7 11-15-2008 01:41 PM
Squeaky Squeaky Kachi TJ Wrangler Technical Forum 4 01-02-2007 03:23 PM
