Squeaking Front End - JeepForum.com
post #1 of 5 Old 05-24-2008, 10:33 PM Thread Starter
DrakeTulloh
Squeaking Front End
About two weeks ago I buried the front end of my 4" lifted jeep with 33s in mud and water for around 16 hours. It was nose down into the water, the water went from the middle of the bumper to halfway between the door and front fender. Both front wheels had water to about an inch below the top of them. When I drive and get above around 15mph it starts squeaking. It did not immediately do this, it started to develop the squeak a few days after it got stuck, and the squeak continued to get worse for the next week, where it then just stayed the same. It does not constantly squeak, every once in a while it will stop for a few minutes and then start back up. I thought the wheel bearings were shot, so I replaced both front hubs, which didn't seem to really help. I also made sure the U joints were properly lubed. The squeaking seems to be coming from about where the driver sits, and up towards the front of the jeep, near the axle. What could this squeaking be? Is there a chance that leaving the front end submerged flooded the differential, or a bearing within the differential or axle assembly?
Thanks,
Drake
DrakeTulloh is offline
post #2 of 5 Old 05-24-2008, 10:53 PM
flatlander757
Check all u-joints and stuff of course.
I've had my brakes make some funny squeaks before when wet or muddy. I'd check them, clean the pads and rotors, lube the contact points, etc. There was one brake noise that I couldn't get rid of that was a sort of faint squeeking about 10mph and up to maybe 35 where the wind noise would drown it out that I found would come occasionally and go away when I touch the brakes just ever so slightly. I just happened to need new rotors and pads due to wear and warpage and after those were replaced the sound is now gone. I'm sure it was due to the "pattern" worn in the rotor with the pads.
You haven't tried isolating the noise by jacking up the front of the Jeep and spinning the wheels?
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #3 of 5 Old 05-24-2008, 11:22 PM Thread Starter
DrakeTulloh
Thanks for the quick reply! This is a really loud squeak. I know it is not the brakes, because i took them off and cleaned them when replacing the hubs. Also the squeaking does not change during braking. I tried to isolate it, but i have to have the wheels spinning too fast before they squeak. I do not want to run my car while on jack stands.
post #4 of 5 Old 05-25-2008, 12:39 AM
flatlander757
Remove the front driveshaft entirely and see if it goes away. The double-cardan joint commonly freezes up when it sees mud or water causing "angry sparrows" noises. Search for angry sparrows for more details.
Currently Jeepless.
post #5 of 5 Old 05-25-2008, 02:33 AM Thread Starter
DrakeTulloh
That definitely sounds like that could be it. It does sound like angry sparrows. Thanks for everyones help!
Squeaking noise coming from front... BWFBezerk TJ Wrangler Technical Forum 5 08-27-2008 11:13 PM
Squeaking noise from front wheels Rush1184 YJ Wrangler Technical Forum 8 02-06-2008 07:22 AM
Front Axel Squeaking? PearlJam1003 TJ Wrangler Technical Forum 2 07-30-2007 10:01 PM
Mud up to bottom of dash...now squeaking at VERY low speeds from front DS Achped TJ Wrangler Technical Forum 8 08-23-2006 02:31 AM
Front end noise (squeaking?) Jaxbrian TJ Wrangler Technical Forum 3 04-23-2005 02:38 PM
