Squeak in right, front wheel - JeepForum.com
post #1 of 62 Old 10-16-2010, 04:14 PM Thread Starter
freeskier93
Ok, this has been annoying me for quite some time. I have this really annoying squeak in the front passenger side wheel. I don't know how to explain it other than it's a rotational squeak, so as I speed up, the frequency of the squeak gets faster. The other thing is when I press the brakes the squeak goes away.
I thought it was the brake pads, but I replaced those about a month ago and the squeak is still there. The only other thing I noticed when changing the brake pads is that passenger side rotor is pretty grooved and the old pads had worn funny. That day I had changed the pads was on a weekend so there weren't any brake places open to spin them, and I've just been to lazy with school to do it. Maybe I'll get around to it this weekend, but I'm not sure that will solve the problem.
The only other thing I could think of it being the wheel bearing...
Any other Ideas?
Oh, and I greased everything a couple weekends ago, not that I expected that to fix anything.
freeskier93 is offline
post #2 of 62 Old 10-16-2010, 04:56 PM
breckboarder55
Could be a sticking brake caliper. The Unit bearings are not serviceable. Do you have any vibrations in the wheel?
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #3 of 62 Old 10-16-2010, 05:08 PM Thread Starter
freeskier93
Hmm, I never thought of a sticky caliper not really sure how I would go about fixing that. I know the bearing aren't serviceable and would have to be completely replaced. As for vibrations, for a Jeep that has horribly balanced tires/wheels and hasn't had an alignment in a while, I barely get any vibrations in the wheel. The only time I get vibes is at 65-75 but they are small.
P.s. I'm getting new tires and wheels next summer, and a couple weeks ago when I was driving out of my neighborhood I had a wheel come off. When it came off it took out all the wheel weights. So don't give me crap about the balanced tires.
post #4 of 62 Old 10-16-2010, 05:18 PM
boarder15675
was that wheel by chance the front right?
boarder15675 is offline
post #5 of 62 Old 10-16-2010, 06:17 PM Thread Starter
freeskier93
Actually it wasn't, it was the back drivers.
post #6 of 62 Old 10-16-2010, 07:47 PM
djt283
djt283's Avatar
Okay you need to explain what led up to your wheel falling off...those things are on there pretty good.
djt283 is offline
post #7 of 62 Old 10-16-2010, 11:27 PM Thread Starter
freeskier93
Well, it doesn't have anything to do with the squeak, but... basically when my dad and I had done the brakes, when we put the tires back on he used the impact wrench, like we have always done. I'm still not exactly sure but slowly the lugs came loose, then one morning driving to school I'm still in the neighborhood and bam, the wheel falls off. I was going so slow, that when I had come to a stop the axle hub was sitting on the inside of the wheel. Found three lug nuts, none were stripped (neither were the studs) and I'm guessing the others had come off over time.
post #8 of 62 Old 10-17-2010, 06:55 AM
fire239
Can you make it squeek with the jeep in the air and spinning the tire by hand? If you haven't done so, try that.
fire239 is offline
post #9 of 62 Old 10-17-2010, 09:58 AM
riscal33
Could be your u joints. If there is any play in them they are shot.
riscal33 is offline
post #10 of 62 Old 10-17-2010, 09:59 AM Thread Starter
freeskier93
Haven't tried that. This week when I address the rotor I'll do this.
Thanks for the suggestions guys! Anyone got more info on the wheel bearing? Or a good thread about it.
post #11 of 62 Old 10-17-2010, 10:12 AM Thread Starter
freeskier93
Ah, totally forgot about that. My dad claims he recently replaced them (couple years ago) but he never replaced them with grease-able ones. So to check this you jack that wheel off the ground, spin it, and look for play?
post #12 of 62 Old 10-17-2010, 10:20 AM
GatorKev
Sounds more like someone took a lug wrench to them for you and wanted this to happen.....
GatorKev is offline
post #13 of 62 Old 10-17-2010, 10:22 AM Thread Starter
freeskier93
Yeah I don't know. But since it's happened we're no longer using the impact wrench and I check my lugs often.
post #14 of 62 Old 10-17-2010, 10:28 AM
Bones741
2015 JK Wrangler
probably u-joint or axel joint
HEEP OF JEEP...
Bones741 is offline
post #15 of 62 Old 10-17-2010, 10:30 AM Thread Starter
freeskier93
U-joint makes sense, but what still bugs me is the fact the squeak stop the second I tap the brakes.
Squeak coming from left front wheel Jay_NH92 YJ Wrangler Technical Forum 6 04-23-2010 07:52 AM
Front Wheel Squeak dz1087 TJ Wrangler Technical Forum 14 09-21-2007 08:12 PM
Squeak from front passenger wheel. Divinitous TJ Wrangler Technical Forum 2 04-25-2007 08:15 AM
steering wheel squeak blang4d TJ Wrangler Technical Forum 3 12-01-2005 10:34 AM
Steering Wheel Squeak drzima TJ Wrangler Technical Forum 3 12-03-2003 11:24 PM
