Squeak from front passenger wheel. - JeepForum.com
post #1 of 3 Old 11-20-2005, 07:11 PM Thread Starter
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Since saturday morning my front passenger side wheel has been making a squeak. It's sorta the type of noise that two metal panels that rub makes. Tis somewhat annoying and tis really pretty loud. It starts @ 25 mph. It doesnt go away on turns nor does it get louder, so i'm assuming tis not bearings. As they would prolly make a louder noise on sharp turns. The only thing that i have found so far from just poking around is that the dust shield for the disc brake does make a vibrating noise when i smack it. Whereas the drivers side shield does not. Tonight i finally get a chance to get it up on a jack and poke at it some.
Any suggestions of what i should look for to diagnose any major problems? Also, i have been told that the dust shield is useless, anyone wanna confirm this? And suggest i remove it?
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #2 of 3 Old 11-20-2005, 07:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Leave the dust shield in place and make sure it's not bent so it's rubbing. Mine bent once and the shrieking screeching noise it made as it rubbed against the rotor scared the crap out of me.
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 3 Old 04-25-2007, 08:15 AM
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
2013 MJ Comanche
any other possible culprits?
Mine seems to increase when going down our local bumpy dirt roads...
ಠ_ಠ
LoneJeeper is offline
Help with a passenger side front end squeak - possible the shock Darteres YJ Wrangler Technical Forum 2 08-31-2009 01:43 PM
Front Passenger side wheel problem weems TJ Wrangler Technical Forum 2 06-13-2009 01:04 AM
when i put it in 4wd the front passenger wheel doesn't engage ImpactFabWorks YJ Wrangler Technical Forum 30 02-14-2009 04:50 PM
Front passenger wheel wobbles? 98TJ38S TJ Wrangler Technical Forum 8 12-13-2008 11:20 AM
Front Wheel Squeak dz1087 TJ Wrangler Technical Forum 14 09-21-2007 08:12 PM
