Squaring poly 4 link brackets. - JeepForum.com
post #1 of 34 Old 07-17-2012, 06:02 PM Thread Starter
Benderff
Benderff's Avatar
I'm either over thinking, or under thinking this. I'm building a 4 link using PolyPerf brackets, and need to square them so the rear end follows correctly.
I'm sure there is a easy way to check this, but I'm tired and have missed it.
So far I have been using this factory slot. It seems to match up on both sides, but I can't say that 100%.
Help a dummy out.
Benderff is offline
post #2 of 34 Old 07-17-2012, 06:41 PM
wushaw
Rockin jeep
wushaw's Avatar
Poly did not provide basic diagrams or dimensions any I take it?
wushaw is offline
post #3 of 34 Old 07-17-2012, 06:50 PM
Imped
Imped's Avatar
Why would they? They don't have a specific location....you put them where you want them.
I use a consistent frame nutsert on each side. Those tend to be very square from the factory. Once you get them tacked, cross measure to verify.
OlllllllO
IndyORV
Imped is offline
post #4 of 34 Old 07-17-2012, 07:02 PM
wushaw
Rockin jeep
wushaw's Avatar
If it's a custom install I can understand you put em where ya want em in relation with whatever your arm lengths are gonna be and squared up on the frame.
Mine is Clayton and I had drawings to go by. You know it was a bolt in kit after you welded in all your brackets.
wushaw is offline
post #5 of 34 Old 07-17-2012, 08:13 PM Thread Starter
Benderff
Benderff's Avatar
Thanks. I moved a set of jack stands so I can measure off the nutserts. Any suggestions on cross measuring? It kind of feels like I'm free balling it so far.
Benderff is offline
post #6 of 34 Old 07-17-2012, 08:24 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
That's all we did on the KOH LJ. We wanted our arms to be around 27-30".
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #7 of 34 Old 07-17-2012, 08:32 PM Thread Starter
Benderff
Benderff's Avatar
If only I had the same caliber of help and/or skill. I'm just some ******* that reads cool stuff on the internet and tries to copy it. I've spent the last hour trying to figure out how to get some dolphins with freakin lasers to square this **** up.
Benderff is offline
post #8 of 34 Old 07-17-2012, 08:36 PM
dcope17
I measured mine from multiple points like the body mount bracket, Front LCA brackets and such. I averaged them out and called it good. This is my first modified Jeep and I can't say I know how a "perfect" one would feel like... but I have no complaints.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #9 of 34 Old 07-17-2012, 08:49 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
As long as your close you'll be able to square up the axles to the same measure points and then cross measure. Don't over think it. You are going to be fine. Don't burn them all the way on until you get the axles, brackets and steering tacked up as well.
Like us on Facebook
Savvy is offline
post #10 of 34 Old 07-17-2012, 08:50 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by Benderff
If only I had the same caliber of help and/or skill. I'm just some ******* that reads cool stuff on the and tries to copy it. I've spent the last hour trying to figure out how to get some dolphins with freakin lasers to square this **** up.
Good thread. I'm about to start the same project & was procrastinating on the rent-a-dolphins.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #11 of 34 Old 07-17-2012, 09:20 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I screw a flat head bolt all the way into the middle frame nutsert. Then I hook the tape measure over it. I use the flat head bolts we use on the Under Armor which lets the slot in the tape measure hook catch on the thin edge.
I've found that nutsert to be really consistent from rig to rig and even if it's off slightly, you can fix it with adjustable control arms.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #12 of 34 Old 07-17-2012, 09:47 PM Thread Starter
Benderff
Benderff's Avatar
Thanks. I noticed one of the body mount brackets was wider at the base then the otherside. That was part of what got me thinking about this. My rig is far from perfect. I just don't want it tracking down the road like a dog.
Thanks. Everything is tacked up now. I lost track of how many times I got something in place and had to pop it off right away to fix it. Some PVC mock up arms tomorrow. Cycle it out, and hopefully burn it in.
Dr. Evil needs to return them soon.
It's little tricks like that I wish I could think of when I'm doing the work.
Benderff is offline
post #13 of 34 Old 07-17-2012, 10:10 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Avoid anything to do with the body mounts. Here is one I removed and relocated higher. After I cut it off the frame, I noticed something odd about it. The smaller hole is the center of the web.
Since I noticed that little oddity, I've started paying attention and a lot of them are that way, but not consistently.
When you get ready, I'll show you a very easy way to square up the axles and you don't even need a tape measure.
I am Savvy
post #14 of 34 Old 07-17-2012, 10:34 PM Thread Starter
Benderff
Benderff's Avatar
The body mount difference is what got me worried. Along with the points I thought would be fix where at odd angles and a pain to measure accurately. I didn't even think about the belly nutsert since I had a jack stand In the way to mark the back corner of the underarmor.
I'd really appreciate learning your method for squaring the axles. I have a habit of making things much harder then needed.
Benderff is offline
post #15 of 34 Old 07-17-2012, 10:42 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea my Clayton stuff was measured off the center of skid inserts, it would seem they (Chrysler) has a good consistent jig for them.
wushaw is offline
Poly Perf track bar kit and drag link (drop pitman or flip kit and your results??) premo JK Wrangler Technical Forum 30 03-17-2014 11:47 AM
Degree Off-set for lower link brackets on a Jeep TJ jhegedus11 TJ Wrangler Technical Forum 11 07-28-2012 07:50 AM
Rear top link brackets for dana 44 grayson_333 TJ Wrangler Technical Forum 2 10-08-2011 09:24 PM
Poly Performance Universal 3-Link Weld-On Front Kit digizure YJ Wrangler Technical Forum 1 10-18-2010 04:59 PM
3-link brackets goldswim5 TJ Wrangler Technical Forum 8 01-13-2010 09:27 AM
